Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
DC-3 / LI-2 / ЛИ-2 / Scale M1:5 by Hungarian modeler
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 05-06-2023, 12:41 PM
  #51
JOZSEF
I think about the construction of the wing and the profile.
This airfoil and wing are too big.
If you have a good idea, write that or upload
the picture or the plan here.
The picture is from the e-book
"Самолёт ЛИ-2" (1946 г.).
Old 06-10-2023, 02:12 AM
  #52
JOZSEF
This drawing helped me a lot to draw the engine nicalle.
The picture is from the e-book "Самолёт ЛИ-2" (1946 г.).
Old 06-23-2023, 02:00 AM
  #53
JOZSEF
This drawing would have helped me a lot when I drew the fuselage of the plane.
Unfortunately, I just found it now.
I found the drawing here: https://rcopen.com/forum/f131/topic427220/27
Do you have any suggestions for moving the flaps on the center wing?
Old 07-09-2023, 01:55 AM
  #54
JOZSEF
Here is my e-mail address if you would like to help me with photos and drawings to draw the wing of the model: [email protected]
You can download this book from here: Áèáëèîòåêà
Old 07-09-2023, 12:53 PM
  #55
F86_SABRE
That link is for the book download but it is in dvju and not pdf..
Old 07-12-2023, 10:56 AM
  #56
F86_SABRE
To move the central flap. The one underneath the fuselage you can make a tongue (an straight extension) from the wing flaps (2 sides) and these lower the fuselage flap. Otherwise make a servo inside the fuselage centre section pushing a horn down. Of course all the three flaps have to be synchronized so that they all go down together. There is no short of walkaround photos of the DC-3 on the net so you should not have any problem locating what you really want.
Reuben
Old 07-17-2023, 01:52 AM
  #57
JOZSEF
Thanks Reuben.
In what scale do you draw and build your own model?
My first idea is 2-2 servos to move the flaps in the middle part of the wing, since the surface of the flaps are large.
The second idea that I like is the movement of the flaps Strula Snorrason's M1:8 DC-3 model.
http://rcsturla.com/douglas-dc-3-photos/
I will ask for his opinion and suggestion
Old 09-08-2023, 11:48 AM
  #58
JOZSEF
I wrote an e-mail to Strula.
I haven't received an answer so far from Strula.
The picture is from the e-book "Самолёт ЛИ-2" (1951 г.).
Old 10-04-2023, 11:42 AM
  #59
JOZSEF
The sructure of the profile is according to my plan.
Old 10-09-2023, 11:20 AM
  #60
JOZSEF
This Solid Edge par.file is in my Google Drive.
Old 12-03-2023, 07:32 AM
  #61
JOZSEF
The fin is with the rudder.
Old 12-07-2023, 11:18 AM
  #62
JOZSEF
They are beautiful together!
Old 12-17-2023, 10:12 AM
  #63
JOZSEF
I use this par. file for the wing ribs.See my Google Drive!
Old 12-18-2023, 02:19 PM
  #64
F86_SABRE
Nice work Jozsef! It is coming out nice. I use Winghelper and Compufoil to make the wings. What material will you be using to cover the wings and elevator stabs? BTW what google drive are you talking about?
Reuben
Old 12-19-2023, 09:40 AM
  #65
JOZSEF
Thanks Reuben!
See post 21: https://drive.google.com/drive/folde...6G?usp=sharing
I plan the fin and the horizontal stabilizer will be covering 2mm balsa and the wing 3mm balsa and 1mm plywood.
Old 12-28-2023, 08:33 AM
  #66
JOZSEF
My friend cut out a wing profile rib.
When I designed the profile of the model in Solid Edge, I needed a sample to check its construction to see if it was strong enough, as the computer does not return the dimensions.
Old 02-06-2024, 09:28 AM
  #67
JOZSEF
The nose part is before the sanding.
Old 02-26-2024, 12:59 PM
  #68
JOZSEF
The structure of the middle part of the wing according to my plan.
Do you have any suggestions about this plan?
Old 02-26-2024, 02:09 PM
  #69
F86_SABRE
- What are the pipe diameters (red tubes)?
- How long are the two tubes inside the center section and how long will these tubes be inside the outer wing?
- Which engines do you plan to use so that you can allocate the firewall position according to the engine. I suppose whoever will be building this aircraft would appreciate to have a firewall position that will fit their engine. My suggestion is to allocate the firewall position with reference to a number of popular engines currently available.
Reuben
Old 02-27-2024, 11:26 AM
  #70
JOZSEF
Reuben-Thanks for your advice.
The dimensions are in mm on the drawings.
Old 03-15-2024, 01:12 AM
  #71
JOZSEF
The diameter of the engine cowl of the LI-2 model is Ø282mm.
I choose a Hungarian model engine MOKI/MARK M360 RC,
You can see the parameters here:
https://mokiengine.com/
I think this engine will be strong enough for this model.
We tested this engine.
Old 03-15-2024, 02:15 AM
  #72
F86_SABRE
Jozsef, Definetely a nice engine and a quality engine. However since the engine is a twin inline one do check about your cooling system especially to the rear cylinder as it will have a tendency to get hotter than the front cylinder. Proper ducting should be made to force the incoming air to go through both cylinders. Do check how you intend cooling the rear cylinder as it is very important!
Reuben
Old 03-21-2024, 11:44 AM
  #73
JOZSEF
Reuben -Thanks.
Old 05-06-2024, 02:04 AM
  #74
JOZSEF
DC-3 / LI-2 / ЛИ-2 / Scale M1:5 WING - Part 1 / Solid Edge Student Edition
Old 05-06-2024, 10:46 AM
  #75
F86_SABRE
Jozsef there is no link to the google drive. If you do not wish to make it public just send me a private message. Thanks!
Interesting video!
Contact Us - Manage Preferences - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service -
