Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
JW Büker Jungmeister build
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 05-22-2022, 12:21 PM
  #51
mitchilito
My Feedback: (7)
I made a .045 layup of fiberglass to replace the piece that goes on the very front of the fuselage. The original wasn't sized to my liking. Then, while I was at it, I decided to fill in the simulated "fuel tank" lines on the top forward of the fuselage. Unless these areas are executed perfectly, they just wind up looking crappy so I decided to eliminate them. My feeling about this is that there are so many other concessions in this kit that compromise scale fidelity that this one won't make much difference. Obviously I'm not a scale fanatic!
Steve (06-13-2022)
Old 05-22-2022, 12:27 PM
  #52
mitchilito
My Feedback: (7)
I needed to work on the smoke and fuel tanks before I glued on the firewall pieces. The smoke tank I'm using is smaller than the kit-supplied gas tank so it took some mods to make it work.
Reducer intalled in the front portion of the smoke tank mount. Plus you see I added some rubber padding.
I like this tank mounting method.
Steve (05-22-2022)
Old 05-22-2022, 12:32 PM
  #53
mitchilito
My Feedback: (7)
And it's finally time to glue on the front of the fuselage. I just retired so I have lots of time to work on these projects. I doubt it will be long til this thing is flying.
This part of the build is pretty fun. All the parts automatically place themselves perfectly. Fun!
Steve (05-22-2022)
Old 05-23-2022, 07:52 AM
  #54
mitchilito
My Feedback: (7)
Time to fill all that daylight in the front frames. The written instructions call out Balsa Wood pieces to fill, but the kit comes supplied with STYROFOAM. IMO styrofoam is good for one thing: stuffing packages for shipping. SO: I pulled out some high-density blue foam to use. The main reason I prefer blue foam is because it sands better and is much more durable. I think blue foam is the absolute perfect material for this application: light but STRONG, and will make a durable surface to glass up.
Styrofoam in the foreground and some of the blue foam I will use above.
Lots of space to fill with foam
Steve (06-13-2022)
Old 05-26-2022, 03:14 AM
  #55
mitchilito
My Feedback: (7)
Ran out of blue foam on the top but I had some similar density pink foam for the bottom.
The factory supplied packing material ☺️
Steve (06-13-2022)
Old 05-27-2022, 06:55 PM
  #56
tmac48
tmac48's Avatar
Do you clean the foam out or does it stay there after fiber glassing?
Old 05-29-2022, 01:35 PM
  #57
mitchilito
My Feedback: (7)
It stays and adds a bunch of strength. Doesn't add much weight but the weight it does add is in the nose where it's needed.
Old 05-29-2022, 04:48 PM
  #58
tmac48
tmac48's Avatar
Ok,thanks
Old 05-30-2022, 09:54 PM
  #59
tmac48
tmac48's Avatar
You must have sanded the front by now!!!
Old 05-30-2022, 09:57 PM
  #60
tmac48
tmac48's Avatar
11 weeks wait on my kit.
Old 06-02-2022, 01:02 AM
  #61
mitchilito
My Feedback: (7)
Actually, I took a little time off from the Bucker because I'm putting a Sig Rascal 110 together for my gas-converted OS Gemini Twin. See the conversion here:
https://www.rcuniverse.com/forum/gas...onversion.html
As you'll see in my conversion thread, I had one a while back. Unfortunately the radio quit and I lost it. Since then I've been missing it like crazy. Plus I needed a home for my gorgeous Gemini!
Old 06-02-2022, 01:03 AM
  #62
mitchilito
My Feedback: (7)
Do you mean you've been waiting for 11 weeks, or you will have to wait 11 weeks?
Old 06-02-2022, 03:49 PM
  #63
tmac48
tmac48's Avatar
Sorry about that, just placed the order, so most likely another 10 weeks now.
Old 06-04-2022, 06:03 PM
  #64
tmac48
tmac48's Avatar
Will be waiting to see how you do the wing to fuselage fairing. I believe on the older kits these were supplied as a fiber mouldings..
tmac48
Old 06-05-2022, 12:19 AM
  #65
mitchilito
My Feedback: (7)
The "older kits" were by a different manufacturer and an entirely different beast. I have a friend that built one and flew it for 8 years. That kit had a finer scale fidelity. His is actually the one you see on Voglesang's website in the JW Bucker gallery - which is funny considering it isn't even a JW kit!I. It's the one in yellow Swedish livery.
I'm not a scale fanatic so I don't mind the concessions to scale accuracy much, but I don't really care for the oversized cabane struts (that go from the fuselage to the top wing). I may make a proper sized set some day.
Here's my friends Bucker. Notice the smaller cabanes:
Old 06-05-2022, 02:16 AM
  #66
tmac48
tmac48's Avatar
I must admit that I'm definitely not an expert when it comes to the Bucker, not having seen that many full scale examples to be able to pick up a lot of the scale details but would love you to show me the two different cabanes as a direct example when you get a moment, not trying to distract you from your build though.
tmac48
Old 06-09-2022, 05:10 PM
  #67
tmac48
tmac48's Avatar
Just had a thought. Seeing that there isn't any fibre fairing fuss to wings, reckon you could make a mould from yours and then you could sell some!!!
Tmac48
Old 06-14-2022, 02:47 PM
  #68
mitchilito
My Feedback: (7)
Progress! I finally got my gas convertet Rascal 110 dialed-in and flying fantastic (I’ll attach the maiden flight but you’ll have to put up with the crappy iPhone 13 video going out of focus and my hoarsing around with the pitch and engine settings. It was a maiden flight after all) and can get back to work on the Bücker:
Foam epoxied and taped.
Here’s the Rascal. A more fun project I’ve never had. The Gasoline Gemini engine is a dream!
Steve (06-19-2022)
Old 06-15-2022, 03:46 AM
  #69
mitchilito
My Feedback: (7)
I meant to show how I pre-sanded the whole front end PRIOR to gluing the foam in. The plywood front end is HARD to sand and the foam would undoubtedly be in harm’s way. Here’s the bottom prepped for foam:
Forgot to throw this picture in here.
Steve (06-15-2022)
Old 06-15-2022, 01:44 PM
  #70
mitchilito
My Feedback: (7)
Almost ready for glassing
The following 2 users liked this post by mitchilito:
SHANEC (06-17-2022), Steve (06-16-2022)
Old 06-18-2022, 01:44 PM
  #71
mitchilito
My Feedback: (7)
I was curious how this beast is going to fit in my Ford Transit so I tossed it in there! It doesn't have the rudder or cowl but I found out what I needed to know: it will fit no problem.
SHANEC (06-18-2022), Steve (06-19-2022)
Old 06-19-2022, 04:37 PM
  #72
mitchilito
My Feedback: (7)
Here it is after 3 plies of 6oz/sq.yd fiberglass. On the top I staggered the layers starting 1/4 inch back of the foam on the fuselage so it would feather in without a hump. On the bottom all three plies butt up against the plywood just aft of the foam. And then a LOT of sanding to get it all smoothed out.
here's the glass weight conversion
Steve (06-22-2022)
Old 06-19-2022, 06:38 PM
  #73
tmac48
tmac48's Avatar
Yep, looking great, just slow down a bit and let me catch up to you when my kit arrives!!
Tmac48.
Old 06-20-2022, 02:36 AM
  #74
mitchilito
My Feedback: (7)
Ha! Didn't you say 11 weeks? I should be flying this thing by then!!
I'll be covering very soon. I pretty much decided on Stewart Systems for the covering and then my good buddy covered his 1/4 scale Spad using it and I loved the way it worked. Can't wait!
Old 06-20-2022, 04:30 AM
  #75
tmac48
tmac48's Avatar
Well then make sure you document all of the build and make my journey less fraught with danger!!
Tmac48
