Loctite your LST2 screws!
#51
OR
RE: Loctite your LST2 screws!
where o' where was this post when i bought my truck! ( i know, right here) I dropped my front drive shaft after about the 4th tank. the only good thing is at least i know its not just me. Personally i hate RTRs for this very reason. why didn't losi offer this as both an rtr and kit? you learn sooooo much more about the truck when you put it together yourself. And, to me anyway thats half the fun of R/C cars is putting em together. Oh well maybe the LST3 will be a kit eh? wishfull thinking.
#52
SC
My friend had his fall out during break through, I knew that I would check mine after I got it out of the box it was tight, then I lost it, got another and used red and it still came out, let it sit over night and so far it's still in.I know theres a flat spot but the screw only gets to tighten down on half of the shaft in mine, making the set screw sit out some, is this normal.....
#53
You're not seating the set screw properly then. It should almost be flush. There is a flat spot on the shaft that the set screw should seat against. Try again.
#55
NJ
My dumb azz didn't listen, finally got the lst2 Runnig Perfect. and wha happuns? its now front wheel drive[:@] I'm toooo stooopid to live[:'(]
hope the LHS has them Fnn grub screws[&o] makes me wanna get enough red lock, to dip my whole truck in it
#57
Use a drill or a dremal tool to make a sizable dent in the shaft your grub screw sits on and some red locktite and it will never move again.............I said shaft[sm=lol.gif]
#58
I suspect some dealers have opened their trucks and played with them before they send them to customs. There is certainly no quality control as it does in the factory in this process.
I am getting my LST2 next week. I hope my dealer does not mass up my truck before seding it to me. Is there any list of check I need to do before I start the engine and hops up I must have for this truck?
Many thanks in advanced!
#59
Just read the manual and maybe search this forum for the break in method of your choice, and just upgrade as you break stuff but it's a great truck right out of the box.
#62
Not sure what to get yet. I would like to seal the bottom of the truck but not sure it is a good idea or is there any parts available. Just got my truck yesterday. It is fantastics. Almost done with the break in.
#63
My lst2 runs so nicely now. It is amazing. So I think I am done with Nitro now. What is the next? Petrol or electric? For the petrol, I like Lauterbacher a lot. J&A T3 Mamba looks good as well. Any suggestion? Not sure about the electric one yet.
#64
Hey Suna
WHere did you get this pic? Do you even have an LST2? Did I sell it to you cause this is my pic. I dont remember giveing out to any one unless you snaked it on ebay. Oh Well I must have sold you yours.
Small world
Small world
#65
Banned
WA
Some screws on my Muggy, (the ones that hold down the servos top plate) popped out half way and were hit by driving over some moguls at the raceway, it bent the screws and shoved them upward making it look like the servo top plate was bent, the screws were a pain to get out and I was wondering where to get Loctite and what type to buy?
#66
Loc Tite can be purchased at any Auto Parts House, Auto Zone, Advance Auto, O'Rileys, NAPA, etc.
Red is the strongest. Need to heat to remove or you will strip out the hex or break the wrench. Also called Stud Lock. Use on drive line grub screws or set screws. Don't get it on the shaft or pin, just the threads and screw.
Blue is a medium Strength and can be purchased as Gap Filling. I use on the wheel nuts. Easier to break loose, but hold good once it dries.
Don't get carried away, it only takes a drop on the threads. Threads need to be clean, oil free. To get full advantage, let set overnight.
#67
CO
Actually green locktite is the strongest. I think its locktite 690. NEVER use this on an rc because it is resistant to heat, vibration, solvents, and Godly forces. Red is the most anyone would want to use. blue is vibration resistant, but can be broken free to replace parts if need be.
#68
1 Post
ORIGINAL: axon22
#69
New LST2. My front driveshaft set screw fell out on first day. Rear screw was still there but loose. I found the replacements at ACE Hardware and used the blue locktite. No problems since. Also had wheel depart on first day. Tightened all 4. I have since gone over all the screws and tightnened as needed. Love my LST!!
#70
It was warm here in Jersey for a coupla days so I splurged yesterday and got my new LST2. Due to my great luck we are now having the biggest snowstorm of the year! Can't think about anything else but running my new toy once warmer weather returns.
Dumb question: Should the screws on the engine head be loctited?
Of note - one screw on the engine head was unscrewed about half way out.
Also, another dumb question: Some of the screws acted like they were loctited, but I couldn't see any blue or red on them.
I did see something clear or opaque flaking off - is there a clear or white loctite?
Thanks all.
Thanks all.
#72
I just use crazy glue for the drive shaft screw(and other importand set screws). When I need to remove them I just heat them up with a propane torch. Havent had a problen ever coming loose.
#74
Well lets hope they fixed teh issue. I will be getting my new LST2 in about a week from now, and I plan on going over it with a fine tooth comb and red and blue loctite.
I will report back here what I find out
#75
I never had any problems with screws backing out, tho my mate had 3 screws fall out from the pan-steering servo plate spacers on his Muggy between tanks 6-9
Think its just luck of the draw with TL trucks if you get one that was made on Monday morning or Friday afternoon! []
