My Custom 1/8 Miss Bud
Old 02-13-2007, 12:37 PM
  #51
47steve
Default RE: My Custom 1/8 Miss Bud
I'll sell my 1/8 miss bud. Brand new hull with speedmaster hardware, insane fin, etc....
Old 02-19-2007, 08:33 PM
  #52
pilot g
Hey buddriver , I am having problems with my hydro , it is brand new and is shutting off after every right turn , did you also got this problem ?
What do you think it could be.
Old 02-20-2007, 12:12 PM
  #53
BudDriver13
Sounds like your low speed needle needs to be tuned. I assume you have a stock Zenoah engine? I would follow the recommended settings in the Zenoah manual and fine tune from there. I used that as my base-line when my engine was stock and dialed it in from there.
Old 02-24-2007, 09:27 PM
  #54
WILDGAS
WILDGAS's Avatar
BudDriver, How fast do you go? What top speed did you find with your configuration?
Old 02-26-2007, 04:09 PM
  #55
pilot g
Bud driver , can you please give me the link were to purchase your turning fin , it`s nice and wide
Old 02-26-2007, 05:50 PM
  #56
BudDriver13
Carlos, the boat runs in the mid to upper 50's right now pretty easily. I can push it a little harder but it get's scary at anything faster and I've been careful with it. I'm working on a few more mods that should help with the higher speeds a little. . . . so keep posted. We'll be taking a video of the boat with GPS soon that I'll try and post for everyone to see.
I posted this earlier, but here is Norman's Bud Boat. Norman helped me with my build and my boat runs pretty much like this video of his just so you can see until I get my video up:
http://media.putfile.com/bud-boat
Pilot, you can purchase the turn fin from www.insaneboats.com. You will have to make a custom mounting bracket as one is not avaible for our boats with this turn fin.
Old 02-27-2007, 07:31 PM
  #57
pilot g
Bud driver , what setup are you running to get the mid 50`s to 60
Which engine , pipe , prop , carb. , flence etc.
Can I get that from you please .
Which prop is the best to run on the hydro`s ?
Old 02-27-2007, 09:29 PM
  #58
pilot g
Buddriver , can you please help me with an address were to buy this engine 35cc A4p Q-Draw Engine
Old 03-14-2007, 07:04 AM
  #59
SEYMOUR RO
How thick is your shim and is it taper
Old 03-14-2007, 11:23 AM
  #60
htlo1r
Budriver, from the photos of the shimmed strut it looks like you just shimmed the back of it.. is that correct?
Old 03-14-2007, 05:17 PM
  #61
BudDriver13
The shim is tapered/wedged from 0 to the front to about 3/16 in the back. You will have to purchase slightly longer screws to use since you are adding space between the hull and strut.
I also have a 0-1/4 wedged shim I sometimes use, but the 3/16s has performed the best for my set-up so far.
Old 03-15-2007, 08:33 AM
  #62
SEYMOUR RO
How thick was your shim and was it taper
Old 04-28-2007, 01:08 PM
  #63
WILDGAS
WILDGAS's Avatar
BUDDRIVER, Do you have any video of your Miss Budweiser in action?
Old 04-30-2007, 11:57 AM
  #64
BudDriver13
Yes, we just took a short video yesterday. I'll see if my buddy can post it this week on youtube and I'll forward the video.
Old 05-17-2007, 07:20 PM
  #65
WILDGAS
WILDGAS's Avatar
ORIGINAL: BudDriver13
BudDriver, Do you have the video?? This weekend I'm going to make a test of my Miss Llumar Modificate.
Old 05-17-2007, 07:27 PM
  #66
BudDriver13
Unfortunately most of the video we recorded was accidently taped over by my signicant other the next day. There is only like 15 seconds to the video left out of the hour or so we recorded. Whoops! I haven't been able to make it back to the lake since to record again. I guess I can try to load the 15 seconds left for the heck of it.
Old 05-20-2007, 09:29 AM
  #67
WILDGAS
WILDGAS's Avatar
BudDriver, Right now, I know why you said that You feel afraid to push all throtle on your Miss Bud.
Yesterday I launch my Miss Llumar with all modification, and It was like ride a Mustang, hehehehehe. The engine has a lot power and I need to remove the back Spoiler to have some control.
I need to put the front spoilers to try have more control.
The high needle was too open, because my engine is new. It runs over 45 mph.
The next weekend, I'm going to close more the high needle, and maybe found 55 mph, but I don't know How to ride this wild horse, hehehehehe
Old 05-20-2007, 02:03 PM
  #68
Glassy cove
Carlos, Was the water calm or chopey and does the front of the boat want to lift or flip with more speed? Thanks Steve
Old 05-20-2007, 06:40 PM
  #69
WILDGAS
WILDGAS's Avatar
The water was calm with a little wind. When I went in front of the wind, my boat wants to do a flip.
I'm going to put front end spoiler, to try resolve this problem, like a BudDriver.
Old 05-20-2007, 10:19 PM
  #70
pilot g
Hello Guys
can some off you tell me more about the zen 7 zenoah engine.
I read that it has 7.3 bhp at 18.100 rpm
How many off you guys can confirm that , or saw the engine runnning
Old 05-27-2007, 08:23 AM
  #71
pilot g
Buddriver ,
Can you please tell me were to buy the pipe holder
Old 05-27-2007, 04:32 PM
  #72
Glassy cove
Hey Bud , I took Miss bud out for the first time yesterday Your Tips that you gave us are the very truth . Read all three pages posted maybe two times I see the same questions repeated but I can see that with out these tips this boat would be onthe the bottom of the lake. I went to lake Piru and found a Big and glassey cove with only a couple of fisherman and ducks . Started it up and let her rip the next thing I new I was out of gas and all the fisherman had multiplied .Thanks again for the bad ass set up . The only problem I had was If you dont get on the throttle right away the nose seamed to plow water into the front of clowing. easy fix NAIL iT Steve
Old 05-28-2007, 01:37 PM
  #73
BudDriver13
Hey Glassy, the pipe holder was custom and hand machined for me. I'm glad to see you got your boat running. With the right set-up, you can get them moving huh!
Wildgas, good to see your boat running too. . . . hopefully the air foils work for you as well.
Old 05-28-2007, 02:14 PM
  #74
mopartybob
Just puttin the finishing touches on Miss Bud and she's ready to go,thanks buddriver13 for the helpful tips on this thread,will post pics shortly.... the only hull mod i added was another cover for the WTC pipe,(did'nt like it exposed)just made a mold of the carb side cover and glassed it in.....[:-]
Old 05-28-2007, 09:06 PM
  #75
WILDGAS
WILDGAS's Avatar
Last upgrade, I put weight in the nose, and push down +3.5 degree the back spoiler.
Right now my Miss llumar is more easy to drive, and the top speed is 46 MPH. I'm going to chance the propeller to a Octura V967 (3 blade) to find more speed. Also i change the pipe 2" band to the original pipe to find more RPM.
The next week end I'm going to launch my Miss Llumar again.
