Tex's first nitro MT-Savage X SS build thread
#63
IL
ORIGINAL: Lunchboxer
Gonna be an awesome basher for sure!!!
I honestly don't think it needs any mods, although I'll probably get shocks. Anything else for this chassis is going to be for the bling. It's all really heavy duty.
It also comes with a bunch of extra parts and an extra set of smaller hex hubs(14mm) for different wheels. The DirtBonz uses the 17mm hubs.
#64
IL
Gonna cut a hole on the windshield to cool the engine?!
![](http://image.rcuniverse.com/forum/upfiles/265968/Vt57450.jpg)
#66
IL
Okay, just curious, as I usually see the nitro car w/ a big hole at the front so the air will flow through...
I think you should wait for the 5T to come out.
#67
LOL, would love one for sure.. 5T, LOL!! That thing is gonna be huge!! Although, not sure what kind of servo would need to pull 1/5th scale truck front tires.. LOL!!
#68
IL
Seriously, the manual says to use a steering servo with no less than 160oz/in of torque[X(]
I have a 3305 for steering and a 3010 for throttle. The 3305 does fairly well, but has a hard time on the carpet. Unfortunately, there is no room for a 1/4 scale servo.[&o]
#69
Yeah, for a car that size, the option to run 1/4 scale would be nice, as it is so much cheaper..
I mean, if you want to get a digital servo that would give you 160 oz-in+, it would be pretty expensive.. compare to a 1/4 scale servo, where 333-oz-in is like $38.. LOL! (not to mention fast.. the S3306 goes 60 degree in 0.16 sec!!)
Tower is allowing the pre-order of the gear-set now.. I will need to order a couple of set.. to rebuild my stripped servo.. at least now they have the servo saver, so it should be okay in the future!!
Got to wait until the end of January to get those gears, though.. argh!! [:'(]
#70
IL
Got the truck started today, but I wasn't able to run it very long. I was able to get it started and running enough to do a circle, but the motor is still very tight. Unfortunately nobody sells the cheap glow starters so I had to get a rechargable one. I don't mind either way as I would rather have this one, but it needs to be charged for 14 hrs. I was able to charge it for like 40 minutes on my drive home, it just wasn't enough though to get it started back up once it cuts out.
That's the only thing holding this up. Tomorrow I'll get back out and try the heat cycle again.
#71
IL
Oh and that engine guard is a PITA when trying to get a hold of the starter handle, I am taking that thing off right now.[:@]
#72
Is it a pull start?!
Would be interesting to see the Savage tomorrow if we are meeting up.. although we might see the track first, no?!
#73
IL
I'll be breaking it in tomorrow, but we can run the track too. The heat cycle method allows you to run the truck normally, but you do it in 2-3 minute runs. alet it cool and then run again.
Ya, put start, the roto start for this motor is $50.
I can pull start it.
![EEK!](images/smilies/eek.gif)
#74
ORIGINAL: []TEX[]
Nah, it gets plenty of air and the cooling head is the size of the motor! Oddly enough, I'll have to use a hot glow plug to keep the temp up. In the summer I would use a cold plug.
Anyways, have fun with that!
#75
IL
ORIGINAL: aer-wubby
Hehe, but that air has to come from somewhere.. Most manufacturers recommend a hole in the windshield so air can get inside your body to cool the head, and come out the rear. Also, glow plug filament temps depend on the amount of nitro your fuel contains.. The lower (20%) should use a hot plug, higher (such as 33%) would require a colder one.
