Expresscraft Cougar Cat with Twins
Old 01-28-2007, 07:56 AM
  #51
crazyotto
crazyotto's Avatar
Default RE: Expresscraft Cougar Cat with Twins
oh boy look at those blue beuties in the hull .. looks like you are gettin there jon , get some glass going and we can see those babies bolted in . did you order the exhaust yet ?? the above post maybe right i never thought about the skegged struts with both props rotating the same direction may cause tracking problems ....maybe .
Old 01-28-2007, 11:50 AM
  #52
firefox144
Hmmmmmm??
Does sound practical. I may have to give top secret a call and see if they are willing to exchange them for me.
The pains of learning a new hobby.
Thanks for the tip, I will study this further.
And yes, I ordered the pipes.
Old 01-28-2007, 01:42 PM
  #53
apache57stryker43
apache57stryker43's Avatar
What the good news is that since the hull has such a wide platform you do not need to counter rotate one engine, agian you will need the struts for proper tracking, what i would do is order two struts with skegs and see which setup works better. I am doing this on my lightning cat build, i ordered the speedmaster strut without a skeg but i also ordererd just the strut itself with the skeg. This way i can do some testing and see what works better. I hope this helps,
JT~
Old 01-28-2007, 05:38 PM
  #54
firefox144
Yes it does, I sent an e-mail to top secret boats to see if they are willing to exchange the parts.
I'm sure they will, I would probably just have to pay shipping plus the difference in cost. I hope.
Hey Otto/Kevin,
I found it, anodized tubing, here I come.
[link]http://www.rbinnovations.com/catalog/product_info.php/products_id/177?osCsid=f20ab13cea3868a9c5e552fc...[/link]
Old 01-29-2007, 08:58 PM
  #55
TERBObob
My Feedback: (21)
TERBObob's Avatar
Just curious if anyone reading this thread has used that alum tubing yet ? Seems with a vibrating engine , and a motionless fuel cell , there would be some fatigue there ..
Old 01-29-2007, 11:07 PM
  #56
apache57stryker43
I always use tygon, have never used the alum,
JT~
Old 01-29-2007, 11:14 PM
  #57
yeeharacing
yeeharacing's Avatar
Otto has it in the drifter but uses tubing to make the connection from the aluminum to the fitting.
I'm planning on using it in my cyclone. Kevin is also using it in another boat he is presently building.
I've only seen it as a hardline along the stringers and then connected with tubing to the fittings.
I plan on bending my stainless steel tubing along the stringer and get it as close to the fitting as possible but I'm still gonna use tubing to make the connection.
Old 01-29-2007, 11:39 PM
  #58
firefox144
yeeharacing said it, I plan to use it for the main runs along the stringers and then
use short peices of flex tubing for the conections
Its all about looks.
Old 01-30-2007, 07:20 AM
  #59
crazyotto
crazyotto's Avatar
ahhhh site looks like it has some fancy stuff there jon , yeah my other cat im using ss tubing for the water and is alot easier to bend to shape for that clean swoopy look to the connector
Old 01-30-2007, 07:32 PM
  #60
firefox144
OK,
Stringers are glassed in, engines are centered And propped up at the angle of install.
Before I actually start drilling, what do you think.
ID:	610306   Click image for larger version
ID:	610307   Click image for larger version
ID:	610308   Click image for larger version
ID:	610309   Click image for larger version
Old 01-30-2007, 08:01 PM
  #61
Ultimate48
Ultimate48's Avatar
ORIGINAL: firefox144
OK,
firefox144
looks great, good clean job glassing stringers in .
keep up the great work !
Steve
Old 01-30-2007, 08:16 PM
  #62
crazyotto
crazyotto's Avatar
looks great to me i see you have good clearance and does the right side carb go on ok as well with room for the velocity stack ..i really like how you cut the stringers looks classy
Old 01-30-2007, 08:28 PM
  #63
firefox144
Haven't checked the carbs yet, I will be getting in the pipes on thursday. I want to mock it all up before I drill them in place.
They say "patience is a virtue" Damn that FedEx guy.
Thanks Ultimate48, What do you guys think about the above link for the anodized tubing.
Also, Warehouse hobbies has announced in-house anodizing for everyone I think.
Check out the bottom of their website.
By the way, overall length of the hull is 59".
Old 01-30-2007, 09:46 PM
  #64
firefox144
installed the carbs for a test fit and have about 1/8" clearance. Pretty tight.
Here are some dimensions for those who are interested.
ID:	610380   Click image for larger version
ID:	610381   Click image for larger version
Old 01-30-2007, 10:27 PM
  #65
crazyotto
crazyotto's Avatar
yeah man that is close !! you dont think it will raddle on the hull do you (lid area )
Old 01-30-2007, 10:56 PM
  #66
Ultimate48
Ultimate48's Avatar
firefox144
yes, I have looked at that site before, very nice !
are you using the anodized tubing in your cat ?
Steve
Old 01-31-2007, 07:46 AM
  #67
crazyotto
crazyotto's Avatar
steve i think he is , he wants a high bling factor ......(fancy)
Old 01-31-2007, 07:00 PM
  #68
firefox144
Yeh, Just having trouble with the location of the fuzzy dice.
Old 01-31-2007, 07:21 PM
  #69
crazyotto
crazyotto's Avatar
hang them off your antenna .....you bebopper
Old 01-31-2007, 08:25 PM
  #70
firefox144
Old 01-31-2007, 10:12 PM
  #71
crazyotto
crazyotto's Avatar
ok now you jon......whats the update for tonight did you do any wrenchin or are you still parts less??
Old 02-01-2007, 07:51 AM
  #72
firefox144
No wrenching, still waiting for the pipes. I will have to make a phone call to see whats up. I know the cooling
manifold is coming today.
I did install the rudder though.
I hate waiting for parts, drives me crazy.
Old 02-01-2007, 08:20 PM
  #73
TERBObob
My Feedback: (21)
TERBObob's Avatar
not really sure why no one else has mentioned this yet but 1/8 inch distance between both carbs is NOT enough ..
Both carbs will be competing for air at WOT . Now , if this is the distance between those useless vel stacks , then , thats a simply fix . loose the Vel stacks .
Old 02-01-2007, 08:39 PM
  #74
firefox144
the carbs are not next to each other, What i meant was that the carb stack has an 1/8"
clearance from the hatch cover to the top of the stack. I dont think it should be a problem tho.
Take a look at the mockup above and you may see what I mean.
Thanks for the input, always happy to learn what I can.
Old 02-01-2007, 09:24 PM
  #75
firefox144
Ok, next update.
While I'm waiting for the pipes to get here, It was driving me crazy that the hatch was an 1/8 of an inch wider than the opening to the hull.
So I pulled out my trusty dremmel and cut a slit along the entire front and two sides of the hatch, then I fiberglassed them back together with some 6oz
cloth, lined the hull with some plastic tape and shoved the hatch in place to dry to shape. Now there even may be some room for paint.
Here are some pics.
ID:	611805   Click image for larger version
ID:	611806   Click image for larger version
