DeHavilland DH-100 VAMPIRE 1/4
#51
RE: DeHavilland DH-100 VAMPIRE 1/4
Warwick
Checked the plans to try to understand your confusion.
There is a flaw in the plans regarding B8 and B9. They are shown on the plans to go all the way to the centerline of the boom. In reality these formers are glued on top of B10 and should therefore be trimmed off 1/8 inch near the centerline.
My plans show when building one boom, you need two B10s.
Per
Per
#52
Hi Per,
Thanks for the information. What you suggest makes sence, sadly not evident on my plans. I will rebuild the booms.
Thanks again
Thanks again
#53
Hi Warwick,
I will have to check this on the plan this evening. Will advise if correction is needed, however, as Per has pointed out, both booms are built completely flat on the work surface and then joined and capped.
Will advise.
Brg.
Kerry S.
Will advise.
Brg.
Kerry S.
#54
Hi Kerry,
By re cutting B8 and B9 and gluing them onto B10 instaed of the stringers all is very straight forward. The way B8 and 9 are cut with notches for the stringers I could not quite see how B10 worked.
All is very good now and progress being made.
Warwick
Warwick
#57
Hi,
The servos that I use in the rudders are these Hitec 5125 MG
This Sunday, more pictures.
Saludos,
Norbert
Saludos,
Norbert
#59
Hola,
These servos are used in gliders of 4 meter wingspan are Metal Gear,are very fiables. The Flight of the Vampire, is how little of a glider, his maneuvers with tail rudders are not very demanding and very well fit the space available. Not a Bandit or similar model, the rest are 14Kg servos on all controls and in the elevators one of 24kg.
Thank you,
Greetings
Norbert
Thank you,
Greetings
Norbert
#60
Friends,
I present the DeHavillan Vampire MkII.
Not finished but there is little in two months
My little dream
Greetings
Norbert
My little dream
Greetings
Norbert
#62
#63
Hola
Some pictures of progress at work, in about a month I can make the first flight.
Thanks ..
Saludos
Norbert
#65
hi guys
ok i could do with a few pointers if possible main one being has anybody got or know where i can locate a stock list for the 1/4 scale vamp? i just got my retracts from sierra and man i got too say they are superb!!! and im hoping too start with in the next week or so but could really do with finding a pretty accurate list of wood needed, thanks for your time.
regards and happy landings
#67
hi norbert
thanks for that i got it ,i know this is going too be a mamouth task but i got too say im really looking foward too it , everybody is so dam helpfull from kerry , too darrell at sierra too the balsa suppliers too you guys i think its going too be sweet , all though a big job im hoping too complete with in a year !!!![X(] thanks again
#69
Hola
There are many, progress, and final decoration is also determined. I put some pictures.
Saludos
Nobert
PS Thanks Pedro, the time is near , I comment soon.
Saludos
Nobert
#71
Hola
After finishing work in construction, electronics and turbine, yesterday we went to make the first flight of the Vampire, it was great, the Vampire responded well to the controls and there was only a problem on landing by a center of gravity somewhat conservative, perfect rest.
There is now only paint finish and enjoy much of their flights.
Thanks Kerry for a good design,
Saludos
Norbert
Saludos
Norbert
#72
Enhorabuena AMIGO
Congratulations my FRIEND
Carlos.
_________________________
http://cmjets.blogspot.com/
Carlos.
#75
Hello Norbert,
It is rewarding to to see the success of your 1/4 Scale Vampire maden flight. I wish you all the best and many many more of the same.
You have executed an exceptional build.
Please send me pics of your finished Painted model as I wish to add them to my customer build files.
Best Regards.
Kerry S.
Best Regards.
Kerry S.
