Is the RCMK EVO really "that" good???
Old 11-30-2009, 06:09 PM
  #51
Dreamin Hemi
Dreamin Hemi's Avatar
Default RE: Is the RCMK EVO really
Old 11-30-2009, 11:25 PM
  #52
moparhemi
Has anybody seen the rcmk rear exoste pull start engine run yet or heard anything about them please let me know. Thanks, Dan
Old 11-30-2009, 11:28 PM
  #53
Ron Olson
Ron Olson's Avatar
Doesn't it make you wonder how much pissin' and moanin' went on when the Zenoah 231 came out and was whippin' on all of those Homie's? When the Sikk came out the Zen lovers were trying to find any way that they could do discredit it and now they've got a bigger fight on their hands! Now the Thunderboat class wants to run Zen only. Well, there's one class that I'll never build a boat for then! To me that's like saying that I can only drive a Chevy or a Ford as it favors only one engine company.
OK, OK, I'm stepping off my soap box now.
Old 12-01-2009, 12:29 AM
  #54
Scott Schneider
Scott Schneider's Avatar
ORIGINAL: moparhemi
Review on MGB in the works .... Very Cool engine !!
Pictures show a STOCK one ... Then modified for my new rigger [:@]
Yes I am doing mods on them when supplied NIB, getting @ $200 for a full race engine with carb mods.
ID:	1324080   Click image for larger version
Old 12-01-2009, 05:06 AM
  #55
lewisdf4
Looks awesome!! Will a zen engine coulper fit the Evo? 2 would be sweet....
Old 12-01-2009, 05:37 AM
  #56
martno1fan
martno1fan's Avatar
Hi mate you need to use a shorter one or machine the zenoah one down or they come loose.
Mart
http://www.gizmomotors.com/index.php...mart&Itemid=56
Old 12-01-2009, 05:44 AM
  #57
martno1fan
martno1fan's Avatar
If you read about it it tells you here .
Old 12-01-2009, 05:47 AM
  #58
Dreamin Hemi
ORIGINAL: lewisdf4
I'm assuming you're speaking of an actual coupler to mate the two Evo's together, right?......NOT the collet.
There is a member here who machies stock aluminum amd makes a very nice coupler bracket. The name slips me now, but that actually reminds me I still have one of his units in my shop for the RCMK. Hopefully he chimes in here as Ionly know his first and last name, not his screen name.
Old 12-01-2009, 06:02 AM
  #59
martno1fan
martno1fan's Avatar
If you mean to couple two together then im not sure but with the inlines they run fine when using stock zenoas but as soon as the zens are modded the cranks get twisted on them so ive been told.Id say a stock rcmk is similar power wise to a mid mod zen so it could suffer the same im not sure .Mind you the 4 bearings on the rcmk might help stop that,the Qd motors use 4 i believe to overcome that issue so it might be fine.Im sure an engine guru will be along to better inform you .
Mart
Old 12-01-2009, 06:38 AM
  #60
lewisdf4
Yeah sorry I am talking about using 2 evo's for an inline. Thanks for the info guys
cheers, chris
Old 12-01-2009, 06:43 AM
  #61
HOOTERS racing
ORIGINAL: Ron Olson
well said mate!!
cheers
Old 12-01-2009, 06:56 AM
  #62
dicko
dicko's Avatar
ORIGINAL: lewisdf4
cheers, chris
Danny at sonic does them. I'm almost positive that a Zenoah one would work on an RCMK, as engine mounts can be used between the 2 engines.
Old 12-01-2009, 07:47 AM
  #63
martno1fan
martno1fan's Avatar
I think hes stopped selling them he only does them with the motors assembled as too many have copied his design.
Mart
http://sonicracingaustralia.com/joined.htm
Old 12-01-2009, 08:44 AM
  #64
moparhemi
Hello Scott, How long does it take you to do one? what do you do to them for $200 And how much HP do you think your getting out of one ? Very interested .Thanks, Dan</p>
Old 12-02-2009, 12:24 AM
  #65
Scott Schneider
ORIGINAL: moparhemi
The modifications are to the Crankshaft, Crankcase, Cylinder, Piston, Intake manifold & carb.
In the case of EVO engines, RPM is raised into the mid 17K to low 18's and close to 6HP or more.
NOT a dyno number chaser but a real world water testing tells the story type of tuner ... been a 2 stroke tech for over 30 years now.
Here are a few Engine Tech articles I have authored in recent years ...
http://www.modelgasboats.com/Magazin...ngine_Porting/
http://www.modelgasboats.com/Magazin..._Modification/
Regards,
Scott
PS.
Once back in the shop doing engine work in January, turn around should be @ 3 weeks or so.
Old 12-02-2009, 10:13 AM
  #66
apache 56
well after chrismass is over and newyears.. i hope to save some coin and get hold of one of these new evo`s....
come on the newyear....and a nother motor.....
Old 12-03-2009, 04:35 PM
  #67
Jamming
Jamming's Avatar
Another positive for the RCMK engines is the 929 carb, keeps a great tune. Also if you have a zen stocker you can buy the EVO head kit and turn a Zen stocker into a EVO Beast, just use the Zen piston and ring. $89.00 or so for EVO performance with a stock Zen motor, Mine flys in my Thunderbolt, Two gallons of camp fuel no problems.
Old 12-06-2009, 06:42 PM
  #68
raptorheli2
i'm looking at a twin inline setup. does anyone know who sells a kit to make the RCMK engines into an inline?
cheers
Old 12-06-2009, 07:58 PM
  #69
danielplace
http://www.rcuniverse.com/forum/post...475&toStyle=tm
Old 12-07-2009, 12:09 AM
  #70
illiniboater
ORIGINAL: Dreamin Hemi
ORIGINAL: lewisdf4
There is a member here who machies stock aluminum amd makes a very nice coupler bracket. The name slips me now, but that actually reminds me I still have one of his units in my shop for the RCMK. Hopefully he chimes in here as I only know his first and last name, not his screen name.
That would be me. I actually forgot I sent you one, you ever get the motors bolted up to it?
Old 12-07-2009, 12:20 AM
  #71
apache 56
hay guys is it worth me buying a evo top end kit and new piston/ring.. and placing on to a zenoah bottom end..
as i have a near new stock zenoah sitting around. or go for a hole new rcmk evo..????....
Old 12-07-2009, 12:45 AM
  #72
illiniboater
ORIGINAL: lewisdf4
cheers, chris
Yes, the inline kit (similar to the one Redline offer) will bolt right up to the RCMK's and Zenoah's. Only differance between the 2 motors is the length of the mounting bolts required for the inlne kit.
Old 12-07-2009, 01:14 PM
  #73
scott09
ORIGINAL: apache 56
Would like to know this too. I have an air g23, can I just use the $89 evo top end and have a much better engine?
Old 12-07-2009, 01:23 PM
  #74
Dockman
To convert your Zen's you will need the EVO Cylinder kit $129 http://www.gizmomotors.com/index.php...mart&Itemid=56
Old 12-07-2009, 02:22 PM
  #75
danielplace
ORIGINAL: scott09
ORIGINAL: apache 56
Is the g23 2 bolt.??????? Air cooled engines bolt the source coil to the cylinder, you will not be able to mount the source coil for lack of mounts for it on the water cooled jug. ??????
