BH Gilmore Red Lion 50cc
Old 08-10-2010, 08:34 AM
  #51
Texastbird
Texastbird's Avatar
Default RE: BH Gilmore Red Lion 50cc
It looks good to go. I hope the inspector shows up!
Old 08-10-2010, 09:43 AM
  #52
jmmt
Congratulations Sonnich, I'm waiting for the maiden flight, I wish you the best of luck. Excellent work...![sm=thumbup.gif]
Old 08-10-2010, 10:09 AM
  #53
SJN
Thanks guys.
Im sure it will be pretty uneventfull, and fly great.
It almost has the outline of a piper cub, just low winged
Old 08-10-2010, 10:29 AM
  #54
Kmot
My Feedback: (24)
Kmot's Avatar
Make certain the batteries in the camcorder are charged as well!
Best wishes for a successful maiden flight!
Old 08-10-2010, 05:38 PM
  #55
Kmot
My Feedback: (24)
Kmot's Avatar
I had my brass tag I made, laser engraved. Maybe you could do one for your Gilmore.
Old 08-11-2010, 02:44 AM
  #56
SJN
looks awesome Tom.
I actualy have access to a laser engraver at work.
But Im a proud owner of an original Chinese ASP engine, so ill just leave it alone for now
Old 08-11-2010, 07:36 AM
  #57
SJN
Well......it did not go too well
ASP started and ran great.
So I lined it up on the strip, and added power.
The Gilmore took off by itself, and climbing at a 10 degree angle, so I trimmed it for level flight.
It was a little gusty today, and it got battered around as if it was a foamy parkflier.
The plane felt a little tail heavy, but it flew fine at 60-70% throttle.
I was just enjoing the engine sound, so I flew it arond as much as possible
Then.......the engine rpm started to sag, right ov er middle of the field.....I tried to lower the throttle a little, and see what happened, and it just decreased further.
So I have it full throttle again, and turned it downwind to fly over the field and then line up an land. But ofcourse the speed was too low at the last leg, and it snaped rapidly, and went in nose first.
It crashd in a water resouvior, and was floating on the surface
I watied until the wind had blown it to the edge, and got it out of the water.
Damage is actualy not that bad at the moment.
Im wating to see how the plane is when all the balsa has dried up again.....see if the glue joints are good or bad.
Engine seems allright.....just have to take it apart now, and oil it up, or it will look like the Titanic inside it...
The pond is deep.......and it is actualy floating in the pictures
ID:	1482424   Click image for larger version
ID:	1482425   Click image for larger version
ID:	1482426   Click image for larger version
ID:	1482427   Click image for larger version
ID:	1482428   Click image for larger version
ID:	1482429   Click image for larger version
ID:	1482430   Click image for larger version
ID:	1482432   Click image for larger version
ID:	1482433   Click image for larger version
ID:	1482434   Click image for larger version
Old 08-11-2010, 07:37 AM
  #58
SJN
Deffinatly an easy repair, if the water hasn`t damaged too much.
ID:	1482436   Click image for larger version
ID:	1482437   Click image for larger version
ID:	1482438   Click image for larger version
ID:	1482439   Click image for larger version
ID:	1482440   Click image for larger version
Old 08-11-2010, 10:05 AM
  #59
Kmot
My Feedback: (24)
Kmot's Avatar
Oh man, sorry to hear about the accident! [][][]
Old 08-11-2010, 03:00 PM
  #60
Strykaas
Too bad Sonnich !
Those images look like they have been taken from a video... Did you tape this flight by any chance ?
Old 08-11-2010, 03:03 PM
  #61
SJN
no, sorry
They where taken from a mobile phone.
But it did sound great while it lasted
Old 08-11-2010, 04:50 PM
  #62
Texastbird
Texastbird's Avatar
Hopefully it will be an easy fix and the Gilmore will fly again soon. With a slighty forward CG maybe.
Old 08-11-2010, 05:04 PM
  #63
SJN
yea.... it is still drying
One of the leading edges of the wings has completly split open almost full lenght.
A rocker cover on the engine has also been damaged.
I hope I can fix it all.
Old 08-12-2010, 02:17 PM
  #64
nilsreinert123
Hi !
Thats how my ASP have been the last year too , stops in the air like you described it , i have changed bearings and all , the engine run fine on the ground , but after 5 minutes in the air it loses rpm and die. It is a bad engine , and i have retired the ASP now . a 9 kg heavy plane needs a reliable engine. I thin i`ll go for a 2 cyl gas engine.
Old 08-12-2010, 02:39 PM
  #65
SJN
Thanks for the info Nils.
Maybe the the carb gets too hot after some minutes of flying when the casing is heated up., and messes up the fuel mixture.
Cant think of anything else that could cause problems.
It would be quite easy to make an insulator block between the carb manifold, and the engine casing.
Old 08-12-2010, 02:44 PM
  #66
Texastbird
Texastbird's Avatar
It couldn't be the carb icing up could it? Is there and O.S. carb that will fit these things?
Old 08-12-2010, 03:06 PM
  #67
nilsreinert123
I think i know one reason , after reading alot on these forums about glow radials . They say it has uneven poor fuel distribution to each cylinder , thats why it loose one cylinder and stops after some minutes in the air.
The saito 325 has a intake fan , and if you go on the OS wbsite and look at the pics of their new 7 cyl it also has a fan in the back . The ASP only have some ducts in the intake.
Thats probably why the ASP fails , the factory should make some improvements to it
Old 08-12-2010, 03:13 PM
  #68
SJN
Well, I ave only flown mine once...so I cant realy conclude anything.
I will have to fly it some more, and then tinker with it.......when i get the plne repied.
Anyone know where you can get replacement part for black horse models ?
Need a cowl, or at least a wing tube....I can repair the cowl.
Wing tube seems to be almost 32mm in diameter.....
Old 08-12-2010, 04:24 PM
  #69
kidcrashalot
I have been following your progress . I am building one with a DLE-55. Earlier in the the thread you wrote it was a little nose heavy. Do you know where the C.G. was located. I am sorry about your plane. You really done a fine job on your exhaust manifold.
Old 08-12-2010, 04:29 PM
  #70
SJN
Hi
My CG was around 10,5cm to 11 cm. I think the manual says 12cm
When I get it repaired, Im going to move it to around 8-9 cm.
Keleo creations mady my exhaust collector...so I cant take credit for that
Old 08-12-2010, 04:39 PM
  #71
kidcrashalot
Thanks for the info. I should have mine ready soon. I will let you know how it does.
Old 08-12-2010, 04:55 PM
  #72
SJN
yea, please tell me how it goes.
Old 08-12-2010, 06:26 PM
  #73
Kmot
My Feedback: (24)
Kmot's Avatar
I have run mine on the ground for 15 minutes at a time....
Old 08-13-2010, 01:35 AM
  #74
Kostas1
Kostas1's Avatar
Ouchh....i feel sorry for you SJN ![]
You definately need a new cowl and wing tube!
IMO the wing tube ,
if i also use my experience with the BH P-36A Hawk (.....see my gallery )
the wing tube is flimsy,soft and you'd better find a solution - a replacement wing tube,
from another manufacturer .......
Just my thought's though...
On my P-36A i just used the supplied one,
BUT remember that the wing tube is GLUED with epoxy between the wing halves....
your wings can be separated.....
Old 08-13-2010, 10:21 AM
  #75
jmmt
Sonnich
I am really sorry to hear about the accident.
Please, can you tell me what kind of on board glow sistem were you using?, brand name?, model name?, and what kind of glow plug?
Contact Us - Manage Preferences - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service -
