CARF Ultra Flash Evo build thread +
#776
Does the connector lock in really nice after connecting both the ends?
I do see the locks on the end of the pins, hoping it locks in real tight.
I am going to use the powerbox standard premium cables (not the maxi) i see they are quite thin and i will have to add a heatshrink to make the wire diameter bigger to be able to crimp on the pins.
#777
Yeah, these lock/clip in really nicely on both ends. To me, they are some of the best quality connectors I've tried. I can connect/disconnect them with one hand while holding the wing. I plan to use the smaller APM connectors (8-10 pins) on future projects. The 20-24awg pins and socket I listed crimped fine with Powerbox standard premium cables (that's what I also used).
#778
Thanks man!
Checking the digikey site, i might be able to ship them to my country.
The pins on your order says 20-24awg not 14?
Do you know if Aeropanda pins are same size as the ones you have used?
I will order from whichever seems most feasible.
#779
I'm not positive what size pins they have included in the Aeropanda set, but I suspect it's the same size I used. Digikey does offer several sizes, so you may be able to find a better fit depending on the gauge of wire used. Also, I still need to get the AMP pin removal tool. It's near impossible to remove the pins once locked into the housing without destroying them. Unfortunately the pin removal tool is rather expensive.
Oh yes, the gauge is 20-24, I'll fix the typo in my other post.
#780
My Feedback: (99)
Check this out:
https://www.rcuniverse.com/forum/rc-...tors-bulk.html
It has the info you desire. Cheers.
#781
My Feedback: (46)
Thanks for the info.
The AMP crimp tool is kind of hard to find in stock right now, I'm currently borrowing one from a friend.
Looks like digikey actually has the crimpers in stock...
#783
Cockpit decals were spare Tailormade stickers from other models, think mainly CARF BAE Hawk 1:5.3
Pilot I cannot remember the manufacture, it’s like an MGA that BVM used to sell, but simpler
#784
My Feedback: (46)
https://dreamworksrc.com/product/sd-...ot-5-17-scale/
#785
I did not consider that a special crimping tool might be required,
i will have a look now.
Do you have a link by any chance?
I used the standard premium cable all throughout my UF and it works perfect. I also used a 24 pin AMP connector for my wing connections and it also has been great. Both highly recommended.
#791
Actually using the better, lighter original tank, it is designed to be 10mm back from the flange-if you are using the cockpit tub you need that for tube clearance on the tub. Also most UF are nose heavy, so that helps the tiniest bit.
#794
See attached pictures, position 1: align tank with wood plate and position 2: all the way forward. I am thinking to position the tank in between these 2 positions, what are your thoughts?
#795
My Feedback: (39)
The distance between picture 1 and 2 looks about half an inch. This will not make a big difference in the final CG position. I suggest to shift it all the way forward if you use a heavier turbine (1500g or more) or slide it back if you use a lighter motor. If you plan on installing a cockpit & pilot, I'd move it back to have clearance for the cockpit tub.
