CARF Joker build thread
Old 10-30-2022, 09:00 AM
  #951
Dave Wilshere
Originally Posted by Andrewfordham
I typically run Savox. So would the 1260 or 1261 be a good fit?
Yes, would work well.
Old 10-30-2022, 09:44 AM
  #952
Bob_B
Bob_B's Avatar
I used 1261’s on elevator and flaps, 1260’s everywhere else. They have been solid.
Andrewfordham (10-30-2022)
Old 12-03-2023, 01:30 PM
  #953
Ruizmilton
My Feedback: (29)
Ruizmilton's Avatar
Hi!
I just bought a replacement Joker, I had lost mine several months ago in a ground roll incident. Mine flew so good I just needed to get a new one, and since I have all the equipment (except the thrust pipe) from the previous one, it made all the sense in the world to just get a replacement. Yet I truly did not like the Carf pipe, when I bought the replacement fuse, the pipe was not available, so I will just go ahead and install a conventional pipe, can any of you guys share the dimension from the rear former of the engine mount to the rear fuselage oulet?
DenisFerrari (12-03-2023)
Old 12-03-2023, 02:53 PM
  #954
jcterrettaz
jcterrettaz's Avatar
I will check that for you tonight
Old 12-03-2023, 03:17 PM
  #955
Ruizmilton
My Feedback: (29)
Ruizmilton's Avatar
Thanks! will look forward for it! Much appreciated!
Old 12-03-2023, 05:52 PM
  #956
jcterrettaz
the bell size its 139 mm on my Joker / the exit pipe 90 mm
im sure like you previous Joker you need to ad some piece of plywood around the pipe at the end. for support .
very simple
BTW sorry for you loss ...I love mine
Old 12-03-2023, 07:29 PM
  #957
Ruizmilton
My Feedback: (29)
Ruizmilton's Avatar
Thanks for this, but I may have not explained myself correctly, I need the distance from the rear engine mount former all the way to the end of the fuselage at the rear outlet, this so I can get the proper pipe length
Old 12-03-2023, 08:15 PM
  #958
jcterrettaz
25 inch incl.bell
Old 12-03-2023, 08:44 PM
  #959
Ruizmilton
My Feedback: (29)
Ruizmilton's Avatar
Thank you!!!
Old 12-06-2023, 10:35 AM
  #960
Ruizmilton
My Feedback: (29)
Ruizmilton's Avatar
Guys, my replacement Joker has arrived, I’m in the assembly process.
My previous Joker I got secondhad, so I did not assemble it, I’m the process of installing the stab servos, would like to know if anyone has used an alternate method to install the servos that will not warp the upper stab skin, any suggestions?
DenisFerrari (12-18-2023)
Old 12-06-2023, 11:40 AM
  #961
Dave Wilshere
If you gently relieve the block to not be forced by the servo case, it won’t buckle the thin skin.
Old 12-06-2023, 06:06 PM
  #962
jvaliensi
See post #812 above. I used MKS 747R servos which have horizontal mounting tabs.
Old 12-06-2023, 09:17 PM
  #963
Ruizmilton
My Feedback: (29)
Ruizmilton's Avatar
Thought about that, I’m using the regular 747’s , MKS used to sell the flat “wing mount” upper cases separately which can be used to modify the regular 747’s, but not anymore, so cannot go that route unless I buy new servos
Old Today, 04:49 PM
  #964
kevinkal
Default New Owner?
Originally Posted by jvaliensi
The intakes were a bugger to get. Schubeler was not good at responding to my requests, although they did eventually reply much later. So, I contacted Gary at Efflux RC, because he sells their stuff in the USA. He was able to get me a set. The are part of the EFD conversion kit Schubeler makes.
They are not a drop in fit. Much cutting and sanding was needed, and I didn't do as good as a job as F-1 did. The fuselage at the intakes needs touch up paint, this is unavoidable. You can see that F-1 added silver paint to LA Jet Guys intakes.
But they do look cool.
Hey,
I was just searching the web and saw your posts for your Joker build. I’m about to do some work on the turbine mounting “plates”. I think mine has similar misalignment issues as you found on yours. Did you still have your Joker?
