Paritech Natrix Build
Old 03-06-2017, 03:01 PM
  #76
berthoud
My Feedback: (35)
Craig,
We may have tried crow a little but I don't recall it doing much. As with anything, it does become easier to land with more time on itand for us, added flap throw made the biggest difference beyond the stock setup although I cannot remember the specific details of how much more I added, probably 10 mm. I never noticed any negative effects of more flaps.
Scott
Old 03-06-2017, 06:04 PM
  #77
dlpeirce
My Feedback: (10)
Originally Posted by CraigG
Darin,
Do you remember how much aileron deflection you have with your crow setup? Any pitch change with the crow?
Thanks!
Craig
Craig,
It's not much, maybe about 3/8". I do not recall any trim change when I put the crow in it just how I reacted the first flight after I did it and thought huh, that did something.
Darin
Old 04-29-2017, 01:55 AM
  #78
Ragz
Ragz's Avatar
I was about to order my second 2.5m Futura. But now I am reconsidering.. perhaps the Natrix.....
Old 04-29-2017, 03:08 PM
  #79
CraigG
My Feedback: (40)
CraigG's Avatar
Well, I've got both. Only 7 flights so far on my Natrix but I would say it flies very similar to the Futura and maybe a little better inverted (less down elevator required). It also looks sleeker (in my opinion). No sense in keeping both so I will probably sell my Futura.
Craig
Old 04-30-2017, 01:05 AM
  #80
Ragz
Ragz's Avatar
Is this model completely made up of CF? I can see most of the pics here have a carbon fin and lots of carbon on the body and wings.. whats the deal?
Old 04-30-2017, 02:56 AM
  #81
CraigG
My Feedback: (40)
CraigG's Avatar
I can't speak for the "standard" Natrix but I ordered mine with the carbon fiber upgrade and it has lots of carbon fiber from near the front of the canopy opening all the way back. The vertical fin is also all carbon. I made sure to put my antennas forward and above the carbon areas. These pics show a little of what I'm talking about.
ID:	2212443   Click image for larger version
Old 05-21-2017, 07:57 AM
  #82
Desert Fox 1
Hello All,
Capture some video of Craig and his NATRIX at the flying field.
Cheers!
Desert Fox 1
Old 05-21-2017, 03:33 PM
  #83
CraigG
My Feedback: (40)
CraigG's Avatar
Originally Posted by Desert Fox 1
Hello All,
http://youtu.be/CmEH4HfpVnU
Cheers!
Desert Fox 1
Thanks for posting Rommel.It wasn't a great day to video with the low overcast but you did a good job! I spent a lot of time on that flight experimenting with the gyro, crow settings and trim (and staying out of the clouds). Even so, I'm starting to get more comfortable with the Natrix.
Craig
Old 05-21-2017, 11:56 PM
  #84
Desert Fox 1
Craig's second flight of the day. Clearer weather
Cheers!
Desert Fox 1
Old 05-22-2017, 05:23 AM
  #85
Bob_B
Bob_B's Avatar
A Natrix with an EDF for push!
https://www.facebook.com/schuebeler/videos/1523822847629826/
Old 08-30-2024, 12:46 PM
  #86
razor.86
Default Any recommendations for CG, Throws and Expo
Guys thank you for sharing your experience with the Natrix. I was wondering if you can please share your recommendations based on experience for the following:
1) Throws
2) CG point (Paritech recommends 385mm from the leading edge I believe)
3) Expos (I am using a Jeti DS 16 II for reference)
I am building mine with a X240 and look forward to maiden it in the coming week
Looking forward to your guidance!
Old 08-31-2024, 04:10 AM
  #87
CraigG
My Feedback: (40)
CraigG's Avatar
Hi Razor,
Here are the settings for my Natrix:
Throws (at the root/inboard edge)
· Ail Up (hi/lo) 30mm/24mm Ail Down (hi/lo) 27mm/20mm·
. Elevator Up 19mm Elevator Down 27mm·
​​​​​​​. Rudder L/R 45mm
· Flaps T.O. 42mm (mix 6% elev down) Flaps Landing 97mm (mix 10% elev down)
CG: 383mm
I fly mine with a Jeti DS24 and a Cortex Pro. These are the settings I use.
Expo:
· Ail 27%
· Elev 25%
· Rud 30%
Gyro gain:
· Clean (flaps up) -32%
· T.O. flaps -42%
· Landing flaps -50%
There is a lot of personal preference with expo but I like the feel of mine with these settings. You might want higher expo if you are not running a gyro. My Natrix weighs just over 17kg (dry) and is very lightly wing-loaded. It flies beautifully but be ready for it to float on landing.
Good luck with the maiden!
Craig
