Building the Ultimate 33% 260 Questions comments and Pictures
#76
RE: Building the Ultimate 33% 260 Questions comments and Pictures
I have never owned a plane that had too much power. Dan's plane with that 110 is about the perfect power to weight ratio, or at least what I like.
That is what the left stick is for
#77
RTK,
I agree the only problem I have is its Tail heavy(for IMAC) and I am too busy to fly it as much as I would Like. It looks Like North Texas will have calm weather on Thursday (10mph wind) so I may be able to get some good trim flights in.
#78
dntmn,,
It might take a little re-arranging of components, but I am sure you will get it all worked out. Keep us posted on how it flies when you get everything dialed in. I'm looking for a new toy and can't make up my mind, so the more information the better.
#79
RTK,
No problem. I will get the final CG, check/adjust lateral balence, check/adjust aileron differential, check/adjust engine thrust, check/adjust ruder-aileron, check/adjust ruder-elevator, check/adjust throttle-elevator for downlines, and set a throttle curve for precision to keep the 1/2 throttle straight and level and the full throttle uplines the same. It will probably take me 15 or so flight to get her dialed in. At this point I should have around 5 gallons through the engine and can fine tune it and switch to 50-1. So far I am extremly impressed. I can give you details on how the 260 flies precision but it will be a while before I play with 3D there is only so much time in the day.
Dan
Dan
#80
Well I have around 4 gallons through this plane(32-1) and will hopefully switch to my post break-in fuel(50-1) today. She is totally Dialed in and all the bugs are worked out. This plane is a rocket. If I pull an upline the plane will go out of site in about 5 seconds. I will soon set a throttle curve for pattern to keep my 1/2 throttle horozontal and full throttle uplines the same speed. I am using a 9Z. I will unleash the full power of the BME Beast for my 3D and sport flying modes. This plane does flies IMAC pattern extremly well. The only manuever I am struggling on is the hammerheads, bit this will come with practice. I am still in a transistional phase after 270 flights on my 28% extra Special, but I can tell that this plane will make me a better pilot.
Dan P
Dan P
#81
Good to hear that the plane is flying well.
I know what you are saying when it only takes about 5 seconds WOT on an up-line to have the plane turn into a dot It sure is nice to have a plane that will flys straight up as fast as in level flight.
#82
My Feedback: (15)
AE, GERMANY
The plane really flies itself. I had awesome mixing setup for mine on the 9303. I thought Tony would have my plane ready this month but looks like July at best!
If I am nuts I might just buy another so I dont have to wait a month.
