CARF Mephisto Build thread
#1103
I just ordered a Mephisto v2 and I'm wondering what tank / engine combo is the best. It appears CMJet has a very large tank and a Jetcat P300 pro is a good option. What do you guys recommend? I'm looking for an engine that has tons of power as I fly at 3000' MSL and can take the Gs and gyroscopic force abuse of 3d flying.
Thanks for sharing your perspective.
#1108
#1111
My Feedback: (99)
That very bent piece of copper goes into the clamp and through the hole in the pipe (that I have plugged with a bolt) for smoke. Has anyone used that setup? I have to disassemble to get into my car and put into a fuse bag so the traditional smoke pipe setup behind the turbine might get bent sticking out--but I'm not sure. Thoughts on the best way to do smoke? I think I will try it out at the end of summer or maybe a bit before so I have plenty of time.
#1116
AEROSHELDON (06-04-2024)
#1117
For those running a full powerbox set up on their mephisto what numbers do you have on the igyro sat for hovering?
I'm running a competition sr2, gps 111 with JR8911 servos
My normal flying set up is
Transmitter 25% gain, vector gain 0%
Gyro gain 75% (stock setting)
Attitude assist on (aileron only)
Characteristic Hard
Stick priority 100%
Lock in feel 25
Air speed factor 4
Characteristic Hard
Stick priority 100%
Lock in feel 25
Air speed factor 4
#1119
Characteristic Hard
Stick priority 100%
Lock in feel 25
Air speed factor 4
Characteristic Hard
Stick priority 100%
Lock in feel 25
Air speed factor 4
200% on Vector (maximum)
Svein Erik Riis (07-10-2024)
