Tex's first nitro MT-Savage X SS build thread
#105
IL
Got some bling on the Savage, I moved the shift point to a higher rpm point and she really winds out nicely. I bought a set of RRP gears to bring her back to a normal ratio.
![](http://image.rcuniverse.com/forum/upfiles/265968/Pn37485.jpg)
#107
ORIGINAL: []TEX[]
Motor mounted onto the motor mount bracket.
The grub screw up front is one of the updates to the Savage X SS kit. This keeps the motor from twisting forward under high torque situations.
Hi TEX,
I intend to upgrade my engine mount using the HD version. However it does not have a front screw similar to new stock engine mount. Do you think it is worth my money to buy that?
Thanks!
#108
IL
Well it all depends. I assume HPI updated the mount for the 4.6
Basically that screw helps keep the front of the motor from flexing down under a heavy load.
If that mount is made of soft alum you may have issues. I think it is more for bling than functional and you won't see any noticable change in temp from those fins.
#110
IL
ORIGINAL: carldav
I see..thanks TEX, how is your savage doing so far? any plans to update this thread with news on your savage?
Here's and updated pic...
#111
Nice! ![Smile](images/smilies/smile.gif)
Also, I bought some "lightened" idler and Aluminum Drive gear to lightened my central tranny, do you think it really lessens the rotational mass of the transmission?
#112
PA
Tex how long did it take you to put the savy. together??? couple hrs? seems strait forward......I think ill go with the SS not the RTR also what servos/radio/receiver do you use? will the receiver and radio from my t-maxx work for now? need servos tho
#113
IL
ORIGINAL: madmax22
The TQ radio will work just fine, but I recommend a high-torque servo for steering. A medium torque servo like the 3010 will also help with throttle control, but a standard servo will work until you can get one. I also recommend you upgrade the Tx when you can. I use a Futaba 3PM.
#115
IL
ORIGINAL: madmax22
I saw this on rcplanet.com the futaba 2pl 2-ch AM / 2 S3003 servos what do you think?
Do this, PM turbotb0205, he is a friend of mine. Tell him I told you to PM him and let him know you are looking for an inexpensive radio with a high torque servo for your Savage. He always finds great deals on radio systems. I'm sure he'll be able to find you something.
#118
Did you get your Savage X SS from Amainhobbies.com? Because the Savage X SS has different tires in the picture of it on Amain.
