Rebel Hot by Comp Arf
#1326
My Feedback: (67)
Question, I have the Infinity scheme and it's difficult for these 54 yr old eyes to always pick up. I have no issues flying it, but would like better visibility. I have some fluorescent orange and fluorescent red/orange vinyl that I was going to put some on the top and bottom wing. However I also thought about painting it (only the top) but not sure how much weight that would add. Any suggestions for increased visibility?
#1328
A nice bright light kit might help.
Fluorescent colors are the easiest to see. Perhaps you could try some vinyl stripes to see if it helps. If not, that can easily be removed. A fluorescent or white stripe on the leading edge of the wings helps bunches.
#1330
For visibility I now have the unilight navigation lights and top light, I don't know what the effect of this lights will be in the summer, but than visibility will be less a problem I gues Smile
The Xicoy x60 is perfect for power, with butterfly programming the plane slowes down very strong and makes landing very easy. Use the powerbox pioneer with gyro that makes the plane flying very stable : I now ordered the GPS to improve the gyro settings.
I also filled up the front nose wheel with 6 mm, becaus I had problems with take off : the nose went down on our wet and bad quality grass flatland airfield. I fly the plane till 4 bft. So if you do all this you can fly minimum 3 years with this plane without problems, becaus I'm almost 57 years old TalkingTalkingTalking
#1332
I may have mentioned this in another thread elsewhere…so not wanting to be repetitious. On my Rebel Pro for competition visibility, I use Orcal fluorescent Red vinyl on the lower wing tips. This makes the orientation very visible even at extreme distances.
Wayne
Wayne
markusvt (07-07-2024)
markusvt (09-11-2024)
