Top Flite Cessna 182 ARF
Old 03-25-2020, 05:33 AM
  #1401
KaP2011
My Feedback: (17)
KaP2011's Avatar
Originally Posted by rowdog_14
Thanks for the feedback for the wing but with 3/8 difference I am not going to worry. With the firewall I did not think that was needed either, but an option I considered. I wanted a solution that was easy to revert back if I did not like the power output of the 90ts.
I wouldn't worry about the small difference either, I seriously don't think it'll make a difference at all. Your engine looks great in the cowl. I did have some overheating issues with my first one with a Saito 1.00. I had cut the bowls out for the lights thinking it would bring more air in. It had the opposite effect by pulling air away from the cylinder head. I plugged the holes with lights and the problem went away.
I think your 90t will be fine, maybe a little underpowered but not much. It should fly in a very scale fashion. My first one with the Saito 100 was slightly overpowered.
KaP2011
rowdog_14 (03-26-2020)
Old 03-26-2020, 12:27 PM
  #1402
elmshoot
KaP2011
Same motor and same opinion
I side mounted the engine and closed off the left side air side. No issues but I never flew in really hot WX before I sold it.
Sparky
Old 04-08-2020, 05:49 AM
  #1403
rowdog_14
rowdog_14's Avatar
Airplane is finally complete. I am going to redo the flaps but they are not actually as bad as I thought, once I aligned and centered all the surfaces. The part near the center section of the wing is still pointed down a little.The plane balances perfect with the 90ts and the batteries located right in front of the landing gear, but without the interior floor and seats.
Old 04-09-2020, 06:20 PM
  #1404
rowdog_14
rowdog_14's Avatar
Here it is!!! Man I can not wait to put it in the air.
KaP2011 (04-09-2020)
Old 04-09-2020, 06:36 PM
  #1405
KaP2011
My Feedback: (17)
KaP2011's Avatar
That's awesome, it looks great. Good luck with the maiden flight and remember,....breathe. You're gonna love this plane when you get comfortable with it.
The following 2 users liked this post by KaP2011:
ply68 (10-09-2024), rowdog_14 (04-09-2020)
Old 04-09-2020, 06:37 PM
  #1406
KaP2011
My Feedback: (17)
KaP2011's Avatar
Unfortunately you're gonna hate the front strut, make sure to keep the nose up when landing.
Old 04-10-2020, 04:36 AM
  #1407
elmshoot
I'm not sure how many pages back I posted fly it like the full size 182, don't land on the nose gear its there only to keep the prop off the ground.
Land on the main landing gear it will land nice and slow even with out the flaps. Get the nose up before touchdown.
Sparky
ply68 (10-09-2024)
Old 04-10-2020, 05:04 AM
  #1408
hookedonrc
hookedonrc's Avatar
Here's mine, but it remains grounded due to engine issues. It has a DLE 20 and the maiden was horrific with either idle or full speed, and nothing in between. I was able to bring it down into some high grass, which did soften the blow. However, the nose gear (sierra) snapped at the wooden block I added per this thread. The wheel, went right through the bottom requiring a repair to the fuse behind the fire wall. Sent the engine in to VVRC and they found a bad ignition pickup, which has now been repaired and back on the plane. While the engine was off, I completely re-plumbed the fuel tank and carb lines, redid the choke lever, and throttle. I did this to make absolutely sure that nothing was rubbing against any other moving part. (rear carbs are nice, but a pain to set up. Any way, engine testing failed yesterday, with the engine not wanting to run at idle, and dying immediately upon acceleration. Next step is to get totally new gas and remix it to specs. I want this in the air but it's first trip was pretty harrowing.
KaP2011 (04-10-2020)
Old 04-10-2020, 05:30 AM
  #1409
rowdog_14
rowdog_14's Avatar
Originally Posted by hookedonrc
Here's mine...
This engine issues did not appear on the ground during range check with the engine running?
Old 04-10-2020, 05:33 AM
  #1410
rowdog_14
rowdog_14's Avatar
Yes heard these bad boys need to be landed like full scale to protect that nose. Will make sure I keep that in mind when landing.
Old 04-10-2020, 08:08 AM
  #1411
hookedonrc
hookedonrc's Avatar
I wish it had, I would never have left the ground. I was able to taxi it out and take off which went well. As I got airborne, the problems started. I was able to keep it in the air by idle, then quick acceleration, and back to idle. It wasn't a pretty flight, that I can guarantee, and gliding was difficult at best. I did get it down though and am now close to finding out the problem. Everything has been checked except the fuel so that will be next. Never gave it a second thought since I have an old Ultra Stick Lite that screams right along with a G26 using the same gas.
Old 04-10-2020, 09:11 AM
  #1412
rowdog_14
rowdog_14's Avatar
Dang that sucks ...
I have had two planes fail the engine running range check. One was a gasser the other was nitro. The gasser would function fine within about 10-15 feet of the model but had crazy throttle issues about 30-40 yards out. Was able to fix the issue before taking up.
Hope your next flight goes as planed!
ply68 (10-09-2024)
Old 04-29-2020, 08:13 AM
  #1413
rowdog_14
rowdog_14's Avatar
Got the two saito 60t mounted! Looking good! I am excited to see these run. Just need to install the tanks and run a link to the servo for the throttle.
Old 04-29-2020, 12:06 PM
  #1414
gva1956
I am working on the kit built version of this plane, but sadly I am missing the windshield.
Any chance someone has a spare front window they would sell?
I would pay $25 shipped to Washington state.
ply68 (10-09-2024)
Old 06-08-2021, 10:38 AM
  #1415
rowdog_14
rowdog_14's Avatar
Where did you get a kit build of this?
ply68 (10-09-2024)
Old 08-09-2021, 12:47 PM
  #1416
rowdog_14
rowdog_14's Avatar
Well finished putting the 182 together. All up weight is 11.75 on a fish scale and 12.4 digital human scale.
Old 04-06-2022, 10:17 AM
  #1417
rowdog_14
rowdog_14's Avatar
Decided to take the plane up on Monday. Flight did not go well. The engine cut out ya out 20 feet 15-20 feet off the ground. Damaged the nose gear and bottom area of plane right behind the nose gear. I think I recovered pretty good.
Got the plane fixed back up and almost ready for a new maiden!
capt1597 (04-07-2022)
Old 10-16-2022, 06:01 AM
  #1418
Steve#02360
Default Parts
I have an unused windshield along with some other parts. wingtips left and right. dummy antennas wing struts and tail cover. You can have it all for $25.00 plus shipping. if you are interested let me know
Steve
Old 10-16-2022, 10:43 AM
  #1419
elmshoot
[QUOTE=rowdog_14;12722799]Decided to take the plane up on Monday. Flight did not go well. The engine cut out ya out 20 feet 15-20 feet off the ground. Damaged the nose gear and bottom area of plane right behind the nose gear. I think I recovered pretty good.
/QUOTE]
If you looked through the previous posts you would see that most guys have had difficulty with firewall strength and nose gear on a long lever arm tearing out the nose gear mount. Given the extent of the damage you experienced, I guess its a good thing that you hadn't done the firewall spacer behind the nose gear because it surely would have bent your Robart Nose gear! I would consider the spacer if you can keep the engine from quitting at the wrong point of the flight. As I have said in previous posts, the nose gear on a conventional gear airplane is there to keep the prop off the ground. Not for landing on! That's what the main landing gear is for. I taxi my model as as well as full scale airplanes with full up elevator all the time (with crosswind considerations) Keep the weight off the nose gear as much as you can.
Sparky
Old 01-02-2024, 11:39 AM
  #1420
DAVE KEPHART
My Feedback: (13)
what size 3 blade prop did you use on the DLE 20?
Old 01-08-2024, 01:00 PM
  #1421
hookedonrc
hookedonrc's Avatar
Sorry for the delay, I had to look, and the plane is up on a storage rack. I am using a MAS 3 blade 15x7.
BTW. The engine problem turned out to be a bad fuel ignition module. Got it fixed, but I haven’t flown it in several years now. I am planning to get that done when weather gets warmer.
Old 10-09-2024, 06:04 AM
  #1422
ply68
My Feedback: (29)
I just received my TF Cessna 182 from Horizon Hobby a couple days ago. It looks exactly the say as the one I bought about 10-15 years ago. Back then, they were much cheaper. I am building this one as an electric. I know this kit is really designed for gas and does not have a battery hatch. How is everyone handling this issue?
Old 10-09-2024, 01:18 PM
  #1423
gixer47
gixer47's Avatar
There is a battery hatch underneath with magnets, you have to cut the covering. It's in the manual.
