RC Tank F.A.Q.
#126
Yes, there are several different types of low voltage alarms on the market, some of them that show the voltage of each cell and some of them that just give you Red Light Green Light, kind of like go, no-go. You can get them from HobbyKing anywhere from about $3 up to about $10. Just go to Hobby King and look for low-voltage alarm, LVA for short.
Ghost@amps1 (04-28-2022)
#127
#128
Oh yeah and add extra room for the wires and plugs please
#130
I found this out the hard way lol. I bought two RC RoardingTop Lipo batts and neither my HL Tiger I or Sherman would take them so I bought two others that do fit, and have to sell the other two, if I can. Whoops measure measure measure!
#131
#134
I have zipped off an email to them already just thought somebody might know .
Some TCB's with a Serial Port 2 can drive the Sabertooth but the 2 I know of Open Panzer and the ASP boards aren't available anymore.
I'm going thru IBU,CLARK,Elmod and others to see if they have the Serial Port 2 output.
Thank you .
PS I found a shop that will have a solution.
This or some version of this will let me through a Y lead go straight to the Sabertooth and on the other side of the Y lead convert PWM to IBUS/SBUS thru a system like this to go to a IBUS/SBUS TCB. .
https://www.flyingtech.co.uk//electr...fc-pixhawk-apm
Thank you .
#135
Yes, those 2000 mAh batteries only run a heavy tank for a few minutes. I run 4500 or 5000 mAh most of the time and it gives me well over an hour of run time. Some folks use lithium ion batteries to get more run time with less weight / bulk, but those batteries have special needs to prevent fires. Start a thread in the main tank forum and you will get more responses to your questions.
OOPS, correction, it's the LiPo batteries that have issues with fire, not Lithium ion.
Welcome aboard.
Welcome aboard.
#136
Talking about battery and battery charging. I thought I would put my two cents in from experience. I've had NiMH batteries sizzle in a charger (luckily I was in the room) burned my fingers as I pulled them out of the charger. An Alkaline 9V battery blew up that was on my shelf of "dead" batteries. I found something weird on the floor and after some detective work found out it was the internals of the 9 V battery. Fortunately no bad experiences with all my Lipos but I'm always present when they charge and they are stored in those special cases that are supposed to be safe if they ignite (I have my doubts about there safety). I also use a quality charger and charge on metal shelves in case something gets really hot.
Ghost@amps1 (07-20-2022)
#139
It depends on the brand. Have you got a photo of the board that burned? If you have an HL board, then you have to replace it with the same brand, and if you have a taigen or torro board, you have to replace that with the same. With taigen/torro you'll have to rebind the tx - rx. And you can always go with a different brand or an after market board but then you need to replace both the board and the transmitter. Again, a photo of what you have now would be very helpful.
#140
Well, it won't let me upload the images/link to something from 10 posts, but the plate that burned was the one on the receiver, it no longer turns on or gives or receives a signal, and both the receiver and the plate on the vehicle are HL 7.0
