Carden Aircraft Post threads here related to the Carden Aircraft line
Carden Cuda Build
Old 04-29-2006, 10:17 PM
  #126
RobT
My Feedback: (17)
RobT's Avatar
Default RE: Carden Cuda Build
I personally vacuum bag ALL of the foam parts. I put laminating epoxy on the balsa, scape it all of and the place the part into the bag. As you pull the vacuum make sure everything stays in alignment and use the shuck to keep it all straight. (shuck stays outside of the bag.
Other people use many different techniques do do the foam parts.
Rob
Old 04-30-2006, 08:00 AM
  #127
ahallock
Rob,
To skin the fuselage the way I did the other surfaces I will need to put weight on them. so that the excess wood does not stick out I guess I could trim off the excess and add the weight. Maybe add some kind of spacer as to keep the weight off the edge of the wood. Any suggestions on how to add the weight?
Alan
Old 09-26-2006, 09:04 PM
  #128
RobT
My Feedback: (17)
RobT's Avatar
Some Pictures of the Cuda from this weeks Fly-In
Thank you Brian Chang for taking the photo's!
ID:	531005   Click image for larger version
ID:	531006   Click image for larger version
ID:	531007   Click image for larger version
Old 10-31-2008, 11:35 AM
  #129
yellowman2513
could you put a fa 82 in it?
Old 11-06-2008, 08:10 PM
  #130
RobT
My Feedback: (17)
RobT's Avatar
I don't know much about the "FA" but cannot imagine needing the power of the 82.
How much does an fa82 weigh?
Old 11-07-2008, 04:59 PM
  #131
as722
Our cuda with a da 50 is ballistic.
Albert
Old 05-30-2009, 11:10 AM
  #132
Ryan Nau
My Feedback: (54)
Ryan Nau's Avatar
How do the Cuda's do 3D?? Im thinking about picking a RTF one up??
Old 06-03-2009, 11:22 PM
  #133
Doug Cronkhite
My Feedback: (34)
ORIGINAL: yellowman2513
Do you mean a Saito FA-82?If so, no chance. If it's an 82cc engine then it'll be WAYtoo much and likely too heavy.
<br type="_moz" />
Old 07-12-2010, 12:17 AM
  #134
davidgeorge212
davidgeorge212's Avatar
Well, this maybe a bump for this thread but I have a question about the cowling on the Carden Cuda. I just got my Cuda the other day and flew it for the first time, this is my first carden aircraft. I did not build it myself but I hired a proffessional builder to build one for me. Anyway, my question with the cowl is when it is properly bolted on the front and the engine is running at low throttle, around 1/4 to 3/8, it will shake back and forth and makes a pretty big rattling sound. Once it gets past 3/8 throttle, things will smooth out and the rattle goes away. We can not figure out just what is causing that or the best way to fix it. The builder says it might be that the fiberglass cowl could be slightly thinner than usual. Would anyone have a suggestion for a good way to fix this problem?
Old 08-24-2010, 07:45 PM
  #135
lazy eight
My Feedback: (389)
lazy eight's Avatar
See the Carden Yak build I started and see the pic Walt put on there. You can do the same thing with your Cuda to stiffin the cowl. Also check your prop balance and engine prop hub runout you may have a vibration problem. I have never heard of the cowls on the Cuda shaking before.
Old 09-02-2010, 09:37 PM
  #136
ExperimentalAviator
My Feedback: (15)
ExperimentalAviator's Avatar
David,
It could very well be that the cowling is a little thin on the rear portion but I would bet that your issue is an out of balance prop. Usually, even the best balanced prop on a Dubro balancer will not prevent all of the cowling and airframe shake. Sometimes you can get lucky with a small motor but not generally with a gas engine.
I have not used the Vess prop balance ring but several of our club members starting using them and there is definitely a big difference in the idle characteristics while using one; much smoother.
The Vess PBR is not too expensive and you might consider giving one a try if you can’t solve the issue otherwise.
http://www.vesspropellers.com/servle...%21/Categories
Mike
Old 10-20-2011, 09:24 AM
  #137
proparc
What would the Saito equivalent in size be to a DA50 for the Cuda. Or, if you were going to put a Saito instead of a DA50, what size would you use.
P. S. I just looked up the Saito engine chart, and there is no single cylinder Saito large enough to pull the Cuda.
Old 10-20-2011, 10:11 AM
  #138
davidgeorge212
ORIGINAL: proparc
Saito does make a 57cc twin cylinder gasoline engine, but it is really expensive.
Old 10-20-2011, 12:45 PM
  #139
proparc
ORIGINAL: davidgeorge212
ORIGINAL: proparc
Yes, you are correct which is why I mentioned the "single cylinder". I think the 57 is $1,000
Old 01-13-2014, 10:55 AM
  #140
5150flyer
I am finishing a Cuda that I started 5 years ago and of course I have lost the plans. I am almost done covering, so now I need to think about installing the hardware.
Can anyone help me with the CG location? Any comments on recommended throws?
THANKS!
Old 01-13-2014, 12:15 PM
  #141
sensei
sensei's Avatar
You might just give Dennis at Carden Aircraft a call, he is a real good guy and will be happy to help you.
Bob
Old 02-17-2014, 02:18 PM
  #142
5150flyer
After 3 long years, my Carden Cuda is built. I have been in the hobby for 25 years and this is a serious thrill to see this to completion.
Old 02-18-2014, 03:46 AM
  #143
sensei
sensei's Avatar
That is one pretty airplane!
Bob
