New Sport Jet: T-One Models Mini Fortune / Mini T1
#1626
TOO LOW, full flaps will smoke them.
They used to recommend SAVOX SV1250MGP which are Torque @ 7.4v - 8.0 kg-cm/111.1 oz-in. Now they recommend AccuTORQ 220SG which are Stall Torque @ 8.4V : 222 oz. / in (16kg).
#1627
Ready for Maiden!
Hi Guys, I'm late to this party, My T-One Mini is ready to Maiden, I got lost in the posts about CG position,,, my only thoughts is that some people had their UAT on the tray, and some had it on top of the fuel tank,, but there is no way I can't have all my batteries above the noseleg,, (with UAT on top of fuel tank).
I've decided I'll maiden it with bigger heavier Rx Batts to bring CG to front of wing tube, and if all goes well, will drop back to smaller Rx Batts which works out around rear of wing tube... does that sound feasible????
Cheers
Bob
Cheers
Bob
#1628
BobFlint: That a good way to go. Start at the front of the wing tube and move to the back as you get comfortable. I think I had mine at the back of the wing tube.
Randy
Randy
BobFlint (04-19-2023)
#1630
markusvt (03-21-2024)
#1635
I have my timer set for 9 minutes and land with reserve fuel remaining. I figure if I push it (and fly slow for a change) I could get 12 minutes easy. I often fly this airplane wide open!!! (too fun)
How??? It's the fuel flow on this G2 Kingtech K-70. It's very low.
I have a stock tank (guessing 1700ml) and a separate, yet stock, smoke tank on top. BVM UAT. That's it.
I could not find any fuel flow numbers in my manuals. However, the G4 K-70 is 230 g/min while the G4 K-85 is 300 g/min (Kingtech website).
Now, contrast that with my Swiwin SW-80. That has an 1800ml tank and I often fly it at reduced throttle. The timer on that airplane is 6 minutes landing with reserve, but less than the K-70. The Swiwin site show 270 g/min fuel flow.
I hope this helps.
I hope this helps.
#1636
I hope this helps.
I hope this helps.
