Balsa USA Fokker E . III Eindecker build
Old 06-24-2011, 08:08 PM
  #151
MajorTomski
MajorTomski's Avatar
Default RE: Balsa USA Fokker E . III Eindecker build
Done! and as so many other report flies quite nicely, calm fun airplane.
landings are smooothe and downright pretty. The Magnum 91 is running in these shots
ID:	1627342   Click image for larger version
Old 10-16-2011, 10:34 AM
  #152
medmann43
Does any one know what the cg should be for the 80" wing onthe EIII
Old 11-10-2011, 06:04 AM
  #153
MajorTomski
ORIGINAL: medmann43
Does any one know what the cg should be for the 80'' wing on the EIII
The manual says 4-1/8 inch aft of the leading edge.
Old 11-11-2011, 12:58 PM
  #154
KitBuilder
KitBuilder's Avatar
Doe anyone make an eindecker with wing warping?
Old 06-10-2012, 09:05 AM
  #155
Mustang Man-RCU
Mustang Man-RCU's Avatar
Mike,
I just came across this thread and your question with regard to anyone making an Eindecker with wing warping. Proctor Enterprizes makes a 1/4 scale kit that is scale and uses wing warping. I bought the plans and had them reduced to 80% which will give me a wing span of 80" and be approx 1/5 scale. I had a 1/4 scale before and found it a little difficult to transport, thus the reduction in size. I know this reply is about a year late but hope it helps.
Regards
Steve
Old 04-23-2022, 05:07 PM
  #156
mrlistener
It's quite striking that the German Oberursel U.I. engines that powered these E.IIIs were a French design, the Gnome Delta, that Oberursel started producing under license before the war.
It seems that if somebody produced dummy radial engines cast of lead that most of these WWI fighters could use them.
I'm working on the Balsa USA Eindecker .90 that I'm powering with an Eflite Power .60 motor. It will be a casual model, mostly for calm, scale-like flying.
Old 04-28-2022, 07:44 AM
  #157
mgnostic
mgnostic's Avatar
Not only the engine, both the Fokker and Pfalz Eindeckers take a lot of inspiration from the Morane Saulnier monoplanes.
Old 04-28-2022, 05:01 PM
  #158
mrlistener
I've put in a wood dummy engine on a plywood disc and now am realizing it needs to weigh about a pound to balance the plane.
Thinking about lead filled brass tubes for engine cylinders.
Old 04-29-2022, 07:06 AM
  #159
mgnostic
mgnostic's Avatar
If you know anyone with a 3-D printer they can print a pretty nice looking rotary. IIRC there is a pretty detailed version on Thingiverse. print it hollow and fill the cylinders with lead.
Old 06-03-2022, 05:32 PM
  #160
mrlistener
Mine flew today in western Colorado at 6800 feet! With Orotex covering and 12 oz. of nose ballast it weighs just under ten pounds. Yikes!
I was nervous but it made a nice flight and good landing!
It's electric powered with an eflite Power .60 motor, 80 amp Spektrum ESC, 5000 mah 6S lipo battery, and 15x6 APC sport prop.
Old 06-26-2024, 09:26 PM
  #161
eveningonly
The workmanship is exquisite, and the production technology is superb!
