TopRc Voyager build
#177
I watched it already on your YouTube channel, great filming
#179
Oleo legs
Have about 20 flights on my Voyager. I think the main and the nose legs are much to stiff...anyone else that have that problem?
I think the springs are to stiff...but where can you find any replacement or does anyone have an solution?
#181
Yeah, on my Voyager the springs were too long. They were fully compressed when the gear was not compressed. I disassembled the gear and took the springs out. I i think i removed 15-20mm of each spring. Then everything worked as butter 😊👌
#182
Even if I brake the oleo does nothing.
If I taxi the voyager the oleo are not moving...not even if I land the aircraft. I have talked to Lior and it seems that I am the only one with stiff springs. Mine is an early v1
#183
I think I try that...do you also have an early version of the Voyager
#184
I sold mine last year to build a Tomahawk F86. But I miss it big time!
here is a video of mine:
you can also see the springs working very well after I cut them 👌 maybe my gear was an early version. I had the old TopRc gear controller.
and here is a vid from last WE of my new F86
hope you get your gear smoothed out 👌👌
Tom
Tom
#185
https://youtu.be/9gDfBucbNhE
https://youtu.be/YkOdTlzhmMg
Tom
Tom
here is mine at landing..stiff as you see
