Need information on small turbine jets
Old 04-26-2019, 08:43 AM
  #176
BarracudaHockey
BarracudaHockey's Avatar
You full well know that its the insurer that wanted the waiver process to reduce the liability through educational programming.
Old 04-26-2019, 09:58 AM
  #177
Propworn
Propworn's Avatar
Originally Posted by speed is life
But.......But......But........the AMA needs an EXPERT, with DECADES of experience at POLICY writing and RISK management. The need for months of SAFETY training and mandatory INSPECTIONS will be ENFORCED.
Waiver? ......I don’t need a steenkin’ WAIVER.....
There is usually a reason for remote tours......maybe AMA needs to step up to the plate and set him up an office in Thule, Greenland
Some people cry out for attention, even negative attention is still attention....
What do you have against Greenland??????
Old 04-26-2019, 12:13 PM
  #178
franklin_m
franklin_m's Avatar
I don't have anything against Greenland. But when I talk remote site, it's a place from which we operated for the purpose of delivering ordnance. And before you get snarky, that's not "delivery" in the sense of shipping and receiving. Pretty amazing what could be done with them despite being still developmental.
Old 08-11-2024, 03:44 PM
  #179
Surfermark
Surfermark's Avatar
Originally Posted by rhklenke
Guys,
I need some information on small turbine jets. I'm mainly interested in jets that are powered by engines like a P-20, T-45, K-30, K-45, K-60 and maybe as big as K-70. I don't have anything like that myself, so I need to know what's out there that guys are flying.
I am not sure this answers your question to many of your questions.
As far as Turbines go based on your above data and keeping in mind it's important to consider reputable manufacturers known for producing reliable and high-performance engines. Here are some detailed recommendations:
1. JetCat
JetCat P-20
Engine Type: Small turbine engine, suitable for smaller jets and ducted fan models.
Thrust Output: Approximately 5 lbs (2.3 kg)
Estimated Price: $2,500 - $3,000
Features: Known for its reliability and ease of use, often used in smaller jet models.
JetCat P-60
Engine Type: Medium-sized turbine engine for larger jets.
Thrust Output: Approximately 13 lbs (6 kg)
Estimated Price: $3,500 - $4,500
Features: Well-regarded for its performance and build quality.
2. KingTech
KingTech K-30
Engine Type: Small to mid-sized turbine engine.
Thrust Output: Approximately 7 lbs (3.2 kg)
Estimated Price: $2,000 - $2,800
Features: Offers good performance and is popular for its balance of power and price.
KingTech K-45
Engine Type: Mid-sized turbine engine.
Thrust Output: Approximately 10 lbs (4.5 kg)
Estimated Price: $2,800 - $3,500
Features: Known for its durability and consistent performance.
KingTech K-60
Engine Type: Larger turbine engine suitable for bigger jets.
Thrust Output: Approximately 15 lbs (7 kg)
Estimated Price: $3,800 - $4,800
Features: Offers high thrust with excellent fuel efficiency and reliability.
3. JetMunt
JetMunt VT-45
Estimated Price: $3,000 - $3,800
Features: Known for being a high-quality engine with advanced features and good after-sales support.
4. AMT Netherlands
AMT Olympus
Engine Type: High-end turbine engine for larger jets.
Thrust Output: Approximately 40 lbs (18 kg)
Estimated Price: $6,000 - $8,000
Features: Considered top of the line, with exceptional power and craftsmanship.
Key Considerations
Availability: Some of these engines might have limited availability, especially during high demand periods.
Support and Maintenance: Choose a manufacturer with good support and access to spare parts.
Compatibility: Ensure the turbine engine matches the size and weight specifications of your RC jet.
As far as matching aircraft to the above engines here are some aircraft models and manufacturers that might/would pair well with these turbines:
1. JetCat P-20, KingTech K-30
These turbines are ideal for small to mid-sized jets, typically in the 1.2-1.5m wingspan range.
Aircraft: BVM Ultra Bandit 1.7M
Manufacturer: BVM Jets
Details: A smaller version of the popular Ultra Bandit, suitable for turbines like the P-20 and K-30. It's known for its precision and aerobatic capabilities.
Aircraft: Skymaster ViperJet 1.5M
Manufacturer: Skymaster Jets
Details: The ViperJet is a versatile jet, offering good performance for smaller turbines. It's well-regarded for its stable flight characteristics and scale appearance.
2. KingTech K-45, JetMunt VT-45
These turbines fit mid-sized jets, around 1.5-1.8m wingspan.
Aircraft: Tomahawk Designs F-86 Sabre
Manufacturer: Tomahawk Designs
Details: A scale jet model that pairs well with mid-sized turbines like the K-45. It's known for its scale detail and smooth flight performance.
Aircraft: CARF-Models J-10 1.8M
Manufacturer: Composite-ARF (CARF-Models)
Details: A Chinese fighter jet replica, offering a good match for the K-45 turbine. It’s designed for performance and has impressive aerobatic capabilities.
3. KingTech K-60, JetCat P-60
These turbines are suited for larger jets, around 2m wingspan and above.
Aircraft: Skymaster F-16 1:6 Scale
Details: A large, detailed F-16 model that requires more power. The K-60 and P-60 turbines offer the necessary thrust to perform scale maneuvers and high-speed flights.
Aircraft: BVM KingCat
Details: A well-known jet in the RC community, designed for larger turbines like the K-60. It’s renowned for its flight characteristics and durability.
Aircraft: Tomahawk Futura 2.1M
Details: A sport jet that’s popular for its aerobatic performance. The K-60 is an ideal turbine for this model, offering a great balance of power and control.
4. High-End Turbines (AMT Olympus)
These turbines are for the largest and most powerful jets, with wingspans often exceeding 2.5m.
Aircraft: CARF-Models L-39 Albatros 1:3.7 Scale
Details: A large-scale, high-detail jet model that requires a powerful turbine like the AMT Olympus. It’s designed for serious jet enthusiasts who want a true-to-life flying experience.
Aircraft: Tomahawk L-39 2.5M
Details: Another large, scale model that needs substantial power. The AMT Olympus turbine will give it the thrust needed for dynamic and realistic flight.
Consider the manufacturer’s support for parts and service, especially for high-end or scale models.
...SurferMark
Old 08-12-2024, 05:12 AM
  #180
Auburn02
Auburn02's Avatar
When AI comes to RCU...
Old 08-12-2024, 05:25 AM
  #181
BarracudaHockey
Yea, it got reported, I'm not 100 percent sure, keeping a CLOSE eye though.
