Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
TMMY Scale Composites 35% scale Cessna
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 08-02-2024, 02:45 PM
  #2001
planenutzz
yes I have all of those antennas had them made for me.
Instrument panel I need to sort out as mine is the old 182Q style and model I am doing is 182T with G1000 panel.
Old 08-09-2024, 05:20 PM
  #2002
scottkieper
My Feedback: (10)
what size servo arms are you using on the flaps 1.25 or 1.5 , trying to set up flaps and do you use all the flaps in the down position [ raido settings ] in %
Old 08-09-2024, 05:33 PM
  #2003
planenutzz
I have not gotten that far but if your back through the thread I am sure others have posted what they have done.
I'd also research what settings the full size uses, given the size of this model that would be a good place to start.
Old 08-09-2024, 05:59 PM
  #2004
slevin1
My Feedback: (23)
I have a couple giant scale Cessnas and it’s usually about 10° for takeoff flaps and 30 to 40° for landing. Use those as a starting points. You’ll probably have to change the throws after your initial flights. Also it’s takes exactly 6 seconds for the full scale flap to travel from 0° to 40°.
Saul
Old 08-09-2024, 06:04 PM
  #2005
planenutzz
good info!
Old 08-11-2024, 09:52 AM
  #2006
scottkieper
My Feedback: (10)
Default Pics
just some pics
Super18 (08-11-2024)
Old 08-11-2024, 01:21 PM
  #2007
planenutzz
your dash is a lot better than the one I got. Original owner must have told them to just supply an old steam gauge dash.
I will make a new one.
Mine is deferred for the time being, still waiting on the brakes and associated hub machining.
Old 08-11-2024, 01:22 PM
  #2008
planenutzz
I will be making an additional 2, perhaps 4 tail mounting points.
Old 08-12-2024, 03:30 AM
  #2009
scottkieper
My Feedback: (10)
what are you making,? im look for some glide scopes. also looking for all the scale [decal ] markings who makes them . what size batterys are you using????
Old 08-15-2024, 01:05 PM
  #2010
planenutzz
additional 2 tail mounting points. No idea on decals, I have not had any luck with those as yet.
DME and other antennas etc try iflytaillies or Jiri Piri
Old 08-15-2024, 04:48 PM
  #2011
scottkieper
My Feedback: (10)
Time to order da150 what size prop and what make that you are using.. if i can ask...
Old 08-16-2024, 01:21 PM
  #2012
planenutzz
interesting approach to getting help. answers are in the posts earlier. good luck
Old 08-16-2024, 03:54 PM
  #2013
scottkieper
My Feedback: (10)
Wow
Old 08-16-2024, 04:05 PM
  #2014
planenutzz
reap what you sow.
Read the posts, there are answers.
Old 08-29-2024, 02:41 PM
  #2015
scottkieper
My Feedback: (10)
Default Tmmy pics
new 150L
The following 2 users liked this post by scottkieper:
planenutzz (08-29-2024), Super18 (08-30-2024)
Old 09-24-2024, 12:15 PM
  #2016
scottkieper
My Feedback: (10)
Inside all done painted ,engine mounted waiting for mufflers and prop. 2 more weeks for that stuff.looking good.
Old 09-24-2024, 01:24 PM
  #2017
planenutzz
came out nice, well done. Instrument panel does look good. Mine is on hold till I get the brakes sorted, friend is doing machining for me.
I need to get all the G1000 surrounds etc for mine, was going to get somebody to program up some functional ones but think it will be too expensive to do.
One thing to watch is with the seats, they are quite flimsy at the outside of the bend and will crack. I am going to put a layer of either carbon fiber or 6oz cloth to that area.
What size fuel tank did you put in?
cheers
P
Old 09-24-2024, 02:38 PM
  #2018
scottkieper
My Feedback: (10)
I put in the stock tank 300 cc see the mounting I did right behind the dash and fill thru the wing
Old 09-24-2024, 03:18 PM
  #2019
slevin1
My Feedback: (23)
Default Interior
That is a wonderful interior. It looks like you can climb inside the plane and fly it.
Old 09-28-2024, 02:04 PM
  #2020
planenutzz
Did that panel come standard with the kit? Looks very good. I am not happy with mine but it was from one of the early releases of this model. I could get iflytaillies to make me one but will be expensive.
I contacted Tommy to see if he can do me a panel like yours.
Old 09-29-2024, 03:52 AM
  #2021
scottkieper
My Feedback: (10)
yes it came with the plane really nice,did you make a cooling baffle for your engine?
Old 09-29-2024, 12:42 PM
  #2022
planenutzz
he sure did a good job of the panel, I have emailed Tommy to see if I can get one. I have not really done much on mine and not even thought too much about a baffle but I think it will be a good idea to have something, even if it is just a shroud to direct airflow over the cylinders.
I am supposed to get all the brakes and machiningg completed by Christmas, hope so as I have a few weeks off then and want to get it up on its wheels and work on it.
Have to collect a few other bits yet, new Powerbox Competition SRS, batteries, Powerbox Sparkswitch RS and Powerbox telemetry bits.
Old 09-29-2024, 12:45 PM
  #2023
planenutzz
Only 300cc?? that is 10 oz, think you will need larger than that. I was going to fit two tanks, the big Dubro but in the engine mount area. Might put too much nose weight on it when they are full though.
I will have to check how much room would be behind the panel.
Old 09-29-2024, 02:09 PM
  #2024
scottkieper
My Feedback: (10)
sorry 3000 cc i will post pics of it mounted
Old 09-29-2024, 02:14 PM
  #2025
planenutzz
thanks mate, was going to say it would be a very short flight.
