Skybolt hangar and clubhouse
#2127
My Feedback: (28)
PA
I have a couple Skybolts, both with OS 61SF long stroke pattern motors. They both fly beautifully with an APC 12/8 prop. The Yellow/Black is an old GP kit built one, completely sheeted, and a lot heavier than the GP ARF. The GP ARF is at 8#, and will almost 3D. I think if I put an APC 12/10, it should hover, and do excellent aerobatics. I bought the ARF at a swap meet, as the owner ground looped it, and damaged the front end. I rebuilt it, and have been flying it ever since. It's a shame that they are now discontinued, and no parts available. Thankfully, I did buy some spare parts while they were still available. Here's a few pics of them-- Dean
#2128
Hello all!
I am currently building a Skybolt from a Great Planes Kit.
Currently, I'm running into two issues I am looking for some help on:
First, How are you all fueling your skybolts? I am considering using a Dubro E/Z fueler as my in-cowl space is quite restrivted. The other way I am considering (but won't look as tidy) is here: http://www.rcuniverse.com/forum/begi...ill-valve.html
Post #24 shows what I'm talking about.
Second, My cabane holters are not touching the bottom of the cockpit floor per the plans. Has anyone had this problem? If so, what was your remedy? The picture in post #16 in this thread shows the same problem I'm having: https://www.rcgroups.com/forums/show...-skybolt/page2
Thanks guys.
Thanks guys.
#2129
Since almost all my builds are scale and cowled I have been fabbing up a 3-line system to give an independent fill/defuel line that goes to a fuel dot on the side of the cowl.
Blue Regular Fuel Dot, from PSP Manufacturing, psp-170-b-n - Chief Aircraft Inc.
You can get them different colors to match so not so obvious. Just ensure it sits above the top of the tank to reduce siphoning when done filling up. The pic may be a bit difficult to see, but there is one shown in the side of the Rare Bear cowl.
Two points to add: My 3-line system is relatively easy to build and use and works perfectly. I use plastic air tubing for all my fuel lines as careful heating allows me to route it both inside and outside the tank to where required. Inside that third line runs down and to the lower left corner and never interferes with the clunk. Some simply add another clunk and that is a possibility, but I like mine better. Personal choice.
Both fittings you refer to were my go to for years and each has good and bad habits. They are quick to use, but there are internal O-rings that tend to dry up and lose perfect seal, (rebuild kits are available) and they require their own fitting on the end of your fill line that comes with the valve. The DuBro is a bit more obvious due to the protruding protective cap.
Most problems I see come from the fact those O-rings leak from both shrinkage and vibrations. Since that one is designed to fit into the carb feed line any air leak is a potential dead stick.
Not sure of your cabane problem. My original Sig Bolt was prebuilt from a kit and the Super came as an ARF.
#2130
Hello all!
Thanks guys.
Thanks guys.
#2131
#2132
,Hello, I am posting here so that I may find this thread again easier. I have recently acquired a super skybolt ARF. I want to refer back to this thread while assembleing. Probably be a while before I start however.
#2134
Cougar,
Mine is the ARF. Found it NIB at local swap meet. I have been looking around the internet for one, but could not find one.
Got this one for little less than price was new. Thinking about putting a Saito 1.20 on it which is also NIB. Got a very good deal on it years ago, but didnt have anything to put it in.
#2137
I'm familiar with it, Strong as an ox, but built that way.
The ARF is relatively light so you may need to install ballast in the tail.. You may also have to mod the firewall to keep the prop spacing correct. Moving the cowl forward a bit may be an option. You just don't want to end up looking like Karl Malden.
Are you able to post some pics?
#2138
Carl Malden? you mean like with a big nose? I havent posted pics before, but now I have a smart phone. Maybe I can figure it out.
I wont be starting the build for some time. The basement is my workshop, and had trouble with water getting in. Had to tear it up and repair with French drain. remove carpet tore out dry wall to seal cracks, etc.
Will be putting man cave back together, after wife finishes remodeling upstairs. I could take pics of model as is now, just to practice. Yeah, thats the ticket.
Craig
Craig
#2141
looks like nobody's posted in a while. Here are some pictures of my 1/4 scale Skybolt built from Bob Divley Plans. I ofiginally crashed it on the 2nd flight in 1987 or so.
original tail.
still finishing the paint, should be flyable soon.
original tail.
#2142
Nice !
What a heartbreak that had to be, loosing your first one like that.
Just found your build thread on this thing..
https://www.rcuniverse.com/forum/gia...t-plans-2.html
#2143
Yes it was a bummer but I had fun building it so not a total loss. I figure that if I get to build it and it crashes on the first flight that I got my moneys worth out of the build. On that one we took pictures on the first flight and it flew so well that on the second flight I was flying inverted and went to loop out of it and pushed the stick the wrong way. I now ROLL out of inverted flight. To ad insult to injury when we went to develop the film from the first flight we discovered that we forgot to put film in the camera. Another good lesson!!! I had 1 wing panel and the tail around forever and eventually mounted the tail on the wall in about 2011. been wanting to rebuild it for a while now but there were just too many planes to build in the meantime. should be ready to fly in a couple weeks.
RICKSTUBBZ (09-15-2024)
