Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
AR-6 Construction Thread
Old 11-15-2014, 09:27 AM
  #201
sahartman21
Default AR-6 Construction Thread
This morning the engine was installed and the incidences were checked.
You align the model until the engine is level.
You then check the incidence on the wing.
I will have to add a shim to increase the wing incidence about 1 degree.
ID:	2047527   Click image for larger version
Old 11-16-2014, 06:36 PM
  #202
sahartman21
Tail surfaces were made from balsa wood and covered with fiberglass cloth.
The pictures shows vacuum bagging the surfaces between layers of peel ply.
It was cold in the garage so the parts were covered with an electric blanket.
ID:	2048035   Click image for larger version
Old 11-22-2014, 10:02 AM
  #203
sahartman21
The tail surfaces were installed.
ID:	2049310   Click image for larger version
ID:	2049311   Click image for larger version
ID:	2049312   Click image for larger version
ID:	2049313   Click image for larger version
ID:	2049314   Click image for larger version
ID:	2049315   Click image for larger version
Old 11-22-2014, 05:49 PM
  #204
sahartman21
Here are some pictures of radio installation:
ID:	2049437   Click image for larger version
Old 11-22-2014, 05:52 PM
  #205
sahartman21
The control horn is being installed using micro-balloons and finishing epoxy:
ID:	2049439   Click image for larger version
Old 11-23-2014, 04:39 PM
  #206
sahartman21
I fitted the nose for a 1 3/4" spinner.
Polyester filler (NAPA version of lightweight Bondo) was used to build up the surface. The nose was then sanded to fit.
ID:	2049647   Click image for larger version
Old 11-27-2014, 09:51 AM
  #207
sahartman21
Now is time to complete the model with the paint job.
Do a thorough job prepping the surface and you will have fewer issues with the paint job.
The pictures show applying a layer of spackle over the surface to help seal pinholes.
Both styles of spackle work fine. Lightweight spackle sticks a little better but takes longer to dry.
ID:	2050531   Click image for larger version
ID:	2050532   Click image for larger version
ID:	2050533   Click image for larger version
Old 11-27-2014, 09:54 AM
  #208
sahartman21
I've been trying shorter landing gear struts on my recent models.
Two sets of holes are on the strut. If the shorter works fine, the extra length will be cut off.
Old 11-27-2014, 04:01 PM
  #209
sahartman21
After the spackle is dry the surface must be sanded smooth.
I used a sanding block with 220 grit sandpaper.
ID:	2050607   Click image for larger version
Old 11-27-2014, 04:07 PM
  #210
sahartman21
A coat of primer was applied next.
I personally like the Klass Kote white primer and that was used.
Approximately 5 ounces of primer was mixed and then allowed to set for 30 minutes.
The mix was then thinned with an equal volume of thinner.
I filtered the mix when poring into the gun.
A conventional size spray gun was used to apply the primer. The air pressure was set at 50 psig.
The parts were set out of the way to dry.
ID:	2050615   Click image for larger version
ID:	2050616   Click image for larger version
Old 11-28-2014, 09:39 AM
  #211
sahartman21
The primer was sanded with 400 grit paper used dry. The model was then blow off with my air compressor.
I followed with some very light coats of yellow automotive paint. The Acrylic Enamel paint was from Restoration Shop.
ID:	2050690   Click image for larger version
ID:	2050691   Click image for larger version
Old 11-30-2014, 12:34 PM
  #212
sahartman21
Stencils were applied to the model and extra areas were masked off.
Several light coats of black were applied.
ID:	2051277   Click image for larger version
ID:	2051278   Click image for larger version
ID:	2051279   Click image for larger version
ID:	2051280   Click image for larger version
ID:	2051281   Click image for larger version
Old 11-30-2014, 12:39 PM
  #213
sahartman21
Sometimes, despite your best efforts, things go wrong.
The masking was removed and also came some paint.
I applied masking tape to the surface before the paint was 100% dry and paid the price.
The next time I will wait at least 2 days after painting before masking off.
ID:	2051288   Click image for larger version
ID:	2051289   Click image for larger version
Old 11-30-2014, 12:45 PM
  #214
sahartman21
I touched up the surface as well as I could and then applied clear coat.
I used a type intended for spot panels. The clear coat was thinned slightly to allow for easier spraying.
Old 12-02-2014, 06:30 PM
  #215
sahartman21
The AR-6 is ready to test fly this weekend.
ID:	2051706   Click image for larger version
ID:	2051707   Click image for larger version
ID:	2051708   Click image for larger version
ID:	2051709   Click image for larger version
Old 02-08-2015, 03:58 PM
  #216
Hobbs88
Scott, How did the new AR-6 do that weekend?
Will it be debut'ing in Pheonix?
Old 02-08-2015, 05:29 PM
  #217
sahartman21
The model flies great! Jim Lime has been flying the model and intends to race it next weekend.
