ZDZ 80 or F.P.E. 5.8
My Feedback: (31)
I have a H-9 Sukhoi that needs a engine my choices are the following a ZDZ 80 or an FPE 5.8 the ZDZ is 1 and a half pound lighter than the FPE and revs 2000 rpms more.
I'm looking for regular acrobatic flying and probably some 3D
thanks
thanks
RE: ZDZ 80 or F.P.E. 5.8
The FPE is also a full cubic inch bigger that the ZDZ. The FPE is actually 95cc. Which nearly puts it in the class with the big 100's. I say for a H9 bird get a ZDZ or BME. DA is good, but the ZDZ and BME will yeild a 2 pound lighter plane. That is really the only two engines for a H9 plane, period.
My Feedback: (8)
I had a friend that had a ZDZ 80 in his Sukhoi and with the pound of lead he had to add to the nose ,it was 27 pounds. Mine with a BME 100 is 26. I would go with the ZDZ also, but you will need some weight up front. He had no unnessisary weight in the plane. FPE engines run great I have a 3.2 that I am pleased with.
Kelly
Kelly
My sukhoi with a GT-80 only weighed 26. It now weighs 24 lbs and 13oz with the DA-100. A buddy of mines weighs 23 with a BME 110. He has 6 oz of weight to balance but those will soon come off as he thinks it is too nose heavy. These sound like some heavy planes. Of course I have been hearing recently of up to 2 lbs variations between the sukhois and more than that between the late modle extras.
My Feedback: (31)
So I can assume is that the ZDZ80 has more torque than the FPE. The FPE weighs 1 and a half more than the ZDZ but I will probably will have to add about 9oz if I go with the ZDZ.
What about servos?
thanks for all the good info and help.
What about servos?
If he had to add any weight to that plane than he didn't arrange things properly. I have seen at least 3 H9 sukhois w zdz80s with out any added weight.
Joe
Joe
ORIGINAL: cowboyway88
Kelly
Kelly
If you build the plane with pull pull rudder and arrange your components you wont have to add any weight w a zdz80. If you want to add nose weight then get a da100.
Joe
Joe
ORIGINAL: evfast
What about servos?
What about servos?
My Feedback: (31)
Ryans,
You offered me some pics of your set up a while back, well I'm ready to build now and the ZDZ will be going in.
Thanks for all your help
Mike
Mike
SC
The zdz80 is a great engine for the sukhoi but we have two a hanger9 sukhoi and extra with the FPE 5.8 . They both balance with no added wt. As for as power I dont no how much if any differnts in the two. We have a zdz80 but we havent put it in anything yet.
My Feedback: (8)
Man my scales must be way off, with the weights you guys are getting. I have Cabon Gear and tube, no pants and holes drilled every and lithiums. But It was a digital fish scale. I hear they aren't very accurite. But according to my (off) scales I took right at two pounds off my plane. TBM website, good info
Later
Later
