OMP - Ohio Model Products Support Forum Discuss products and get support from OMP. This forum is operated by the owners of OMP and your support questions or complaints will be handled as OMP deems appropriate.
Please, Wich props?
Old 03-17-2005, 07:18 AM
westy1957
westy1957's Avatar
Default Please, Wich props?
Hello,
I got a 65" Yak 54P Kit and I will power it with a YS 110 FZ,
and a 42" Boxxer Kit that I will power it with a YS 63 FZS
I ask: what are the best props you recommend for those beautiful combos?
Are the right engines for those palnes?
Ciao
Paolo
Old 03-17-2005, 07:29 AM
Woody218
My Feedback: (24)
Woody218's Avatar
Default RE: Please, Wich props?
On my 65" Yak with a YS 110, I run an APC 17x4W.
Old 03-17-2005, 07:37 AM
joeb102072
My Feedback: (9)
joeb102072's Avatar
I would say as westy did anywhere in the 16X4W to a 17x4W depending on throttle response 16x6 may work. Its never an exact science some times you need to bite the bullet and try a couple to make sure. As for the .63 I use a 13x4W and I am completely satisfied. Some people say a 14x4W works for them I didnt get the throttle response I was looking for where I may have gotten it from the 14x4 I chose the 13x4W. ITs a gental balance between dia and pitch for 3D some people rather have the dia vs the W in the prop. Hope this helps.
Old 03-17-2005, 09:06 AM
westy1957
westy1957's Avatar
Do you think is right to use APC 12.25X3.75 on JS 63 and also on OS 46 AX ?
And more: is right to use APC 15X6 on OS 91 4T pump and GP Ucando ?
And on the YS 110 wich prop? 15X6 is not good?
Old 03-17-2005, 02:28 PM
joeb102072
My Feedback: (9)
joeb102072's Avatar
To be honest I dont know what a JS is but at .63 it sounds like a 4 stroke. IF that is I think its a bit too small. As for the 46AX i used a 12x7 on my Super tiger 45 and a 11x6 depending, so In both respects I think its too small of a prop. The 15x6 on the .91 maybe a bit too big but its worth a try it may work out. I had a OS 91 and used a 14X6. For extra speed I would go to a 13X8. And a 15x6 is s bit too small for the the YS 110 a 15X8, 16x6 or for 3D a 16x4W
Old 03-17-2005, 09:06 PM
aviti
My Feedback: (54)
16x6 APC on my 65 Yak with YS 110. Perfect combination in my opinion.
Old 03-18-2005, 01:33 AM
westy1957
westy1957's Avatar
Thankyiou!!!
(the engine was an YS and not JS, mistake)
Old 03-18-2005, 06:03 AM
remcl1
remcl1's Avatar
Do not use a 12 1/4 x 3 3/4 prop on a YS 63. You will over rev and ruin your engine. I use the Masteraircrew 13 x 6 scimitar. I have used many different props and this one works the best for slow high alpha maneuvers. Check out my web site you will find videos of this setup doing the stuff. I like the 16 X 4 on my 65" yak with my ys 110.
Old 03-18-2005, 06:57 AM
joeb102072
My Feedback: (9)
joeb102072's Avatar
Yea defintalty to small on the YS .63 I use a 13X4W on mine and I love it. Morris Knife Profile YS .63 13x4W prop awesone combo for 3D.
