idle engine
NY
idle engine
When an engine idle's does it continue to build heat? or will the heat stay constant? If an engine has been driven for 10-12 minutes and then brought in to idle will it cool down? Thanks for the help
RE: idle engine
Yes it will cool down but not like when you shut off your engine. It will still hold heat but as the engine idles for a bit.....it may drop the tempurature by alittle.
