i need help installing my rantec rotor on my os 91
To install the rotor rantec on my os 91,Do i remove backplate, lock key and live only the washer behind the backplate.
Does this sounds right
please help
Raven
please help
Raven
Joe I tried yesterday without the washer and the rotor felt like it was hitting the crankcase then with the washer and it felt right
ANOTHER QUESTION?
How to Install the rotor on the eng, eng keeps spinning I don't now how to tight the bolt that holds the rotor.
Please help.
Raven
ANOTHER QUESTION?
Please help.
Raven
My Feedback: (48)
Raven,
Mine felt fine without the washer, and it was not contacting the crankcase.
Ramtec has a rotor wrench that keeps the rotor from rotating while you tighten the bolt. The newer Ramtecs come with the wrench. I've tightened many without a wrench by putting a piece of wood into the exhaust port to keep the engine from rotating. Others have coiled a rope into the glow plug hole, or filled the chamber with oil (keep the engine upside-down to keep it from running out while tightening) to keep the engine from rotating. These methods aren't as good as the wrench because it puts a lot of strain on the con rod, but they all work.
Joe
Joe
