Hay Check 6,
There is a club member with a DLE 20 in one and I've seen G38 installed into the airframe. What ever you can stuff into the cowl will work and its one beautiful flying model.
Soft Landings Always,
Bobby of Maui
Hi All,
Thanks for the input. I'm going with a DLE 35 RA. This should pretty much fit into the cowl with the rear exhaust and rear carb.
Thanks again,
Fred
Kerwin, I believe my friend balanced the plane by adding a really nice tricked out tail wheel, and by mounting the receiver pack back further than normal.. putting a receiver pack in the tail can really change a CG
