DLE30 High and Low Speed Needles
My Feedback: (17)
These needles are slightly different. The distance from the seat to the end of the tapered needle on one is longer than the other. Also the taper is different. So the question is which needle is high and which is low. - they must be different for a reason. Thanks, Al
BC
My Feedback: (17)
Thanks - you are absolutely correct I was so focused on the tapered end of the needles that I did not notice that the threads were different.Of course I might have figured it out when I tried to install them. Anyhow I did learn something - thank you. Al
