Problem with eme 55 elettric auto start !!!!!!
Hello Guys
I mounted this http://www.sdshobby.com/special-elec...e-p-11462.html
on my eme 60 but is already the second time that break the teeth of the 'main gear.
Someone 'else has had the same problem?
sorry for the English translated with google
Ciao
Francesco
Ciao
Francesco
My Feedback: (45)
Hello Guys
Ciao
Francesco
Ciao
Francesco
I was so waiting for a spate of posts like this to happen!!!
That install is a little tricky, if not done just right would cause a break in the gears.
For those who do their own install make sure it has very little resistance on the workings, when spun by hand.
Use plenty of grease and don't run it without a prop, it needs a load or it will rev out and stuff up.
Hello
I always used with the propeller and checked the operation is always fluid, or the same but I have broken the teeth of two gears and you can not use too much grease, because the injection sensor can be dirty with the risk that goes off the engine in flight
Francesco
Francesco
