Heavy Modified Baja 5b SS
Selling a 1/5 scale rc buggy with lots of goodies in excellent condition probably doesn't even have more then 5 hours on the engine, most of the upgrades are new and probably worth double what I'm asking for with everything included, there's pretty much enough spare parts to build another Baja with all the stock parts that was replaced. It's almost rtr just needs your choice of transmitter and receiver and the Baja needs a new battery. Everything In the pics (Except Stand, DDM dominator pipe and TR pull start) plus some extras come with it all the spare parts, all the manuals, oils and tools with original box. I'm even including a DDM racing banner! I'll try and list most of the parts. Let me know if your interested. (I switched out the TR pull start and the DDM dominator V2 pipe for stock)
oBaja 5b SS Kit
oA Custom Quaggies Carry Dirt Bag
oTeam Fast Eddie Hinge Pin Shims, TFE Pro Shim Kit, TFE Front Camber Shims, TFE Steering Post Shim Kit, TFE Bleeder Caps and Rebuild Kits, TFE Front Hub Cones, TFE Complete Bearing Kit, TFE Oversized Wheel Bearings
oOuterwear Crankcase Flywheel Cover, OW Pull Start Cover, OW Oil Filter Covers, OW TR V2 Pull Start Cover
oTGN Redneck Dual Stage Pre Filters, TGN Billet Filter Cap
oHostile All Terrain Front and Rear Tire Set, Hostile Rear Zero Growth Molded Foam, Hostile Plastic Spur Gear
oHD Bead Lock Ring Set, Front and Rear Super Star Wheel Set
oDDM Clutch drum carrier, DDM HD Front and Rear Shock Springs, DDM Racing Banner, DDM Enclosed Wheel Nuts
oModified Rc Quick Release Roll Cage Tubes, Modified V1 Rear Bumper
oRPM Roof Guard, RPM Front Bumper and Rear Bumper, RPM Front and Rear Arms
oSkull Gas Cap
oTeam Chase Carb Diaphragm Filter, TC Shock Uprights
oKiller RC Light Controller, KRC Bumble Bee Remote LED, kRC LED Headlights, KRC Power Switch, KRC Super Bee Kill Switch, KRC Limiting Cables, KRC Radio Box, KRC Brake 6 LED Light Bar, KRC Pro Suspension Cables
oAirtronics Throttle Servo
oTurtle Racing HD Top Plate, TR One Piece Brake Mount, TR HD Tranny Plate, TR Front and Rear Shock Tower Braces, TR Billet Differential Case, TR 17T Pinion, TR V2 HD Clutch System, TR Quick Diff Transmission, TR Transmission Cap Slug
oGBE Rear Engine Mount
oFull Force High Flow Fuel Line Kit, FF Smoked Windows, FF Billet Cage Risers, FF Extended Spring Cups
oBillet spur Gear Carrier, Billet Engine/Chassis Brave Mounts
oD's Brake Pads Upgrade and Disk Brake Shim Kit
oThreshold Servo Saver Spring Support, TH Hight Pressure Seal Kit
oVVC HD Shock Bottom Cap Set
oIRP Stand Off Turnbuckles Spacer, IRP Front Turnbuckles, IRP Front and Rear Rod Ends
oHostile Big Bearing Hubs, HR Axle Boots
oHD Rear Shock Mount
oFull Kill Quick Release Throttle Linkage
oPhat Dad O-Rings, PD Fan Cover Saver
oDark Soul Front and Rear Shock Shafts, DS Gen 3 Dogbones, DS Toobz, DS V2 Axle Extender Set
oRB Innovations Cooling Clutch Plate
oShread Industry's Inclined Shread Stack
oNew Hemistorm Addict Body Shell
oDuda Spring Loaded Flag
oBad Horse Shock Covers
oFutaba Temp sensor
oTools - DDM Allen Hardened Steel Drivers, DDM Hex Driver T-Handle, DGI Flywheel Puller, Piston Stopper, TFE Port Cover Set, Billet Air Filter Maintenance cap, Hostile Bearing Press, DS Toobz Install Tool, TFE Boot Install Tool, Duratrax Ultimate E-Clio Tool, 1.5 - 5mm wrenches and Ect...
oBaja 5b SS Kit
oSkull Gas Cap
oFutaba Temp sensor
