You guys have any special techniques for aligning the turbine to a bifurcated pipe or do you just eyeball it? Looking up the tail pipe is not the same as a straight pipe it seems.
Find a card tube that just goes inside the pipe and set the length so you can slide it inside an inch and have the tube protrude 1 1/4”. (30mm) it will get you much closer
