Best charger for 11.1V lipo (T-rex 2200 Mah and EVO Lite 2500 mah)
BC, CANADA
What is the best charger for 11.1V lipo batteries and where is the best place to get it? Thanks.
RE: Best charges for 11.1V lipo (T-rex 2200 Mah)
ORIGINAL: Whistler71
its around $75.00
BC, CANADA
ORIGINAL: Night_prowler26
Well There is really no Best charger, I don't have one myself but I really like the Cellpro made by FMAdirect.com. you can buy it from them, its a simply plug and play charger but it works great, i know a few guys who has them and I plan on buying one soon.
its around $75.00
its around $75.00
ON, CANADA
FMA Celpro IS the best charger. Plug and ply. It will fast charge, deciding on its own the charge rate depending on the condition of the batt. Few chargers will do multiple charging. It will charge an overdischarged batt. that few, if any chargers can do. Probably the safest charger out there. Can you tell i'm a satisfied customer?
BC, CANADA
ORIGINAL: Flypaper 2
BC, CANADA
There's a long thread on RC Groups in the general thread on peoples viewpoints on the Cellpro if you want to check it out further.
ON, CANADA
As far as I know, the only place is from the FMA website now. I used to get them from the local hobby shop but they quit selling them to distributors. Check it out at there website. Lots of other goodies too.
VA
RE: Best charger for 11.1V lipo (T-rex 2200 Mah and EVO Lite 2500 mah)
What about the Super Brain 989? Quite a bit more pricy...?
http://www2.towerhobbies.com/cgi-bin...&I=LXEYD4&P=ML
This is a great charger that will charger any type battery. It also comes with its own power supply so you can use it with AC or DC power. It has 2 outputs so you can charge 2 batteries at once, even if they are different types. It is a plug and play charger or you can adjust the rates you perfer.
BC, CANADA
How about the Competition Electronics turbo 35GFX? Or the Thunder Power TP1010C?
Sorry, but I really want to have as many opinions as possible. Thanks.
ORIGINAL: badazzbusa
It's a good charger but not the most user friendly in my opinion.
My Feedback: (13)
KY
Not sure what you want but the link that has been given is a battery cycler not a charger if you want a good charger get a Triton 2 it will charge any battery you have including your car battery
IL
The Cellpro 4S gets my vote. It will automatically balance charge up to 4 cells. If you want to charge up to 10 cells FMA has a NEW balancing charger coming out later this month that will do 2-10 cells (or multiple packs simulataniously). These are probably the safest Li-Po chargers you can buy. Check their website: <http://www.fmadirect.com/detail.htm?...section=45>
They also charge the new A123 cells that are becoming popular.
Whatever you get MAKE SURE it "balance charges" Li-Po batteries. Any other type will just shorten the life of the battery.
Mine has been working great! If I ever upgrade to a heli that needs a 5-6 cell Li-Po I will definitely buy the new Cellpro Revolectrix 10s
Dave D.
Dave D.
