A123 wiring
IA
RE: A123 wiring
Outssider,
Sorry if this is too obviousWhen wiring your plane you must make sure the yellow center tap wire is severed after the charge jack and switch so it does not connect to the receiver!
Stan
Stan
MA
RE: A123 wiring
ORIGINAL: outssider
there is a separate jr plug for power to the rx that has only the + and -. the balance/charge plug is only for charging.
my tanic pack has a deans connector for rx switch to rx, and a male futaba / jr plug for igniton switch and charge jack , i run a single battery for my planes A123 2300mah 6.6v battery pack with charge lead, 1 Deans connector.
