filling shocks
CT
RE: filling shocks
any LHS should have pure silicone shock oil in a wide array of viscosities (weights). which one to use depends on several things including what kind of car you have and how you drive. generally speaking the lower the weight of the oil (viscosity) the lighter (thinner) it will be and it will provide less damping action. there are other things that will effect the damping as well, including the number/size of the holes in the plate that slides inside the shock piston. i typically use 40 weight in my t-maxx. it seems good to me for all around driving. i would say to buy one or two bottles of different viscosities and see what suits you. you'll want to use the same fluid in all of the shocks (well, you can use different weights, but that will come with tuning experience) so empty the others and refill them with the new fluid.
MD
RE: filling shocks
if you don't have a lhs, you can always get some from here http://www3.towerhobbies.com/cgi-bin...+oil&search=Go
CT
RE: filling shocks
ORIGINAL: Dokioto
If your not changing the other three shocks oil make sure you use the same WT in the empty one as the other three..
but you're absolutely correct. if he knows what weight oil is in the other 3, just use the same weight and fill the empty one.
also, try to figure out why the oil leaked out in the first place. you might need a rebuild kit.
RE: filling shocks
I lost all the oil because I hit a tree and bent the crap out of the shock. I did order a rebuild kit. thanks for the info.
____________________________
Giter done
Giter done
