WHATS THE DIFFERANCE ?
Old 12-05-2009, 03:44 PM
rcslsafut
rcslsafut's Avatar
Default WHATS THE DIFFERANCE ?
can any one tell me if there is a differance between the pro.15 and the 2.5 maxx trucks
the reason why i ask ,looking for a pipe for my .15 maxx with a os 18 rear exhaust
everything i find is for the 2.5 t maxx. i think the chassis length ,engine placement
and shock tower is in the exact same place on the two . but before i buy this header
pipe combo and find out its wrong .i would like to know if they are the same.
i think the trans is a little different on the 2.5 ,and i think thats about the only
differance. can u guys conferm this ? any help would be appreciated.
Old 12-05-2009, 04:58 PM
ELK
Default RE: WHATS THE DIFFERANCE ?
The difference between the pro.15 and the 2.5 maxx trucks are the engine size
Old 12-05-2009, 05:14 PM
Snook Man
Snook Man's Avatar
<p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-family: Arial; font-size: 9pt">The biggest difference between the .15 and 2.5 is the exhaust for the .15 is a side exhaust and the 2.5 is a rear exhaust.
The 2.5 header will not work on the .15 engine but will work on the .18TM.</span>
</p><p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-family: Arial; font-size: 9pt">The .15 is a rotary carb and the 2.5 card is a slide valve carb for future reference.
The trannys are the same on the .15 &amp; 2.5. The 2.5R/3.3 trannys are different.</span></p>
</p></p>
</p>
Old 12-05-2009, 09:12 PM
rcslsafut
rcslsafut's Avatar
so , snook? when did they change a arms make them wider ?
and i read some where the chassis thickness is different?
Old 12-05-2009, 09:17 PM
rcslsafut
rcslsafut's Avatar
oh ya and how would you make the 2.5 header work on the os?
the 2.5 header bolts on to the engine as the os is held on with a spring
so there is really no way i see to hook the spring on the 2.5 header
iam looking at header pipe combo from rd logics to fit my t maxx
Old 12-05-2009, 10:28 PM
Snook Man
Snook Man's Avatar
My post should have read it wont fit on the 2.5 or .18th.
Sorry for the confusion.
And yes the 2.5 also has the wide maxx suspension.</p>
Old 12-06-2009, 03:24 AM
rangerfredbob
My Feedback: (13)
yes, the switch to the 2.5 added the widemaxx arms, an extra .5mm thickness of the chassis plate (I believe, could have been 1mm, I don't remember), bigger driveshafts, rear exhaust (as opposed to side exhaust), slide carb as opposed to rotary, better shock towers, the addition of bulkhead braces, and a more intelligent ezstart
Old 12-06-2009, 11:05 AM
rcslsafut
rcslsafut's Avatar
as far as the placement of the engine and the shock towers[so the head pipe will clear]
they are the same though? and has anyone used rd logics pipe ,header?
Old 12-07-2009, 12:17 AM
rangerfredbob
My Feedback: (13)
the engine mounts are the same, shock towers have the same dimensions, the upgrade for the 2.5 just made the towers beefier, they added that cross into the middle and two additional shock mounting options. other than the thickness of the chassis plate the only difference between the older and newer is the 3 holes for the throttle bellcrank
Old 12-07-2009, 10:01 AM
Mopar Or Nocar
Mopar Or Nocar's Avatar
ORIGINAL: rcslsafut
I have the rd logics pipe on my t-maxx, it is very loud (even though i like the sound). It makes it very hard to tune and it doesnt make as much power as a side exhaust.
Old 12-08-2009, 08:55 PM
rcslsafut
rcslsafut's Avatar
i should have been more specific
i already have the rear exhaust,hate it,to loud,horrible to tune!!!!!!!!!!!!
rd logics has a side exhaust and header combo that is what i am looking to get!!
Old 12-08-2009, 08:56 PM
rcslsafut
rcslsafut's Avatar
by the way thanks for the info!!!!!
