Composite-ARF Extra 330L 2.6M WING SPAR
My Feedback: (23)
[8D]hello gent's
i need to make a fuse conection stronger
and the first idea was a carbon tube with the two phenolik for each side to run in
...but i run out of space so [&o]
i noticed in comp.arfs giants have spars to join the wings
..... since aluminium spar would be heavy... is there any sorse links to carbon spars?
i am interesting for a 60cm lenth to 5cm or 6cm to 1cm wide estimate...
maybe one of you have a spear one that wont need?....
thanx in advance for any replyes! and sorry for bad english[8D]
RE: Composite-ARF Extra 330L 2.6M WING SPAR
Why would you need to make the fuse connection stronger?? If you have the floating spare there is no connection to the fuse, it is not meant too.
My Feedback: (23)
ORIGINAL: RTK
hey rtk
i need to make a fuse conection stronger ..of a jet!
not the fuseof the Composite-ARF Extra !
my mistake beouse my bad english sorry
