Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > The Clubhouse
I NEED CLOSURE ON THIS TOPIC.. NOT FOR IT TO BE CLOSED.
The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
Old 01-06-2004, 12:59 AM
Jim C.
Jim C.'s Avatar
Default I NEED CLOSURE ON THIS TOPIC.. NOT FOR IT TO BE CLOSED.
After reading this thread, my buddy here next to me, we'll call him Beaker, and I decided to do a little experiment. Not a full DOE Taguchi Design, but a little 10(4x) hand off experiment to see if the 9z and T6 can be handed off safely.
Results:
Out of 40 handoffs, we tuned the 6xa off once and never on the 9z.
We did however on both radios manage to reverse the ailerons, reset the flap deflection, re-adjusted the throttle mixture, changed to three different models, and managed to go from FM to PPM and back to FM.
CONCLUSION:
Do not hand off computer radios, there are too many buttons that, if pushed in sequence, can and will make changes. Now, there is no big yellow disclaimer sticker on the radio saying this, nor have I found it in the instructions, so, should Futaba be liable for not telling us that it is risky to hand off radios from one person to another, or do we take it upon ourselves to use common sense.
I'm glad this thread came up, I was taught and until now, teach without a buddy cord, but not now on a radio with a dozen or so buttons on it. I am ordering a few more buddy cords.
how and what were you doing to change it from fm to ppm and back again??? are you like throwing it 30 feet at each other or what?? it takes me like 40 seconds to get to the page in a 6xa.. and yes.. i own one. i dont understand how it is possible..i have done the hand off many times..and i have NEVER had a problem.. its called a piece of tape over the on ./ off switch. and unless you manhandle the radio..im not sure how you can change soo much? what planes are you flying .. or i should ask.. how low are you flying your planes that you have to do such a quick hand off? i had to take a plane deadstick at 30 ft up.. and there wasnt no urgency.. there is a correct way to do a handoff.. dont move the radio.. the student holds the radio, and the instructor grasps it,and the student moves out of the way for the instructor.. and it can be done actually faster than handing the radio itself over. just my two cents.
and by the way.. FUTABA is not to blame. PERIOD also.. im not referring to the 9z.. i have the 9c.. and i still cant see messing things up that bad.. i dont know what the 9z is like so i have no comment on that one.
[link=http://www.rcuniverse.com/forum/Un%2Dsafe_switch_design_in_the_Futaba_9C%25_Struck _a_person/m_1397875/tm.htm]http://www.rcuniverse.com/forum/Un%2Dsafe_switch_design_in_the_Futaba_9C%25_Struck _a_person/m_1397875/tm.htm[/link]
Old 01-06-2004, 02:27 AM
3DFanatic
Default RE: I NEED CLOSURE ON THIS TOPIC.. NOT FOR IT TO BE CLOSED.
Not to mention PPM is FM...
For that matter, PCM is also FM and PPM is really PWM...
Old 01-06-2004, 07:46 AM
stomper
My Feedback: (20)
ORIGINAL: GraupnerFan
Results:
CONCLUSION:
Your kidding right? You put a piece of tape over the on- off switch? Whats the problem with using a buddy cord?? I don't get it!
Old 01-06-2004, 08:24 AM
Jim C.
Jim C.'s Avatar
no im not kidding.. i was just throwing suggestions ... so anyways... never said anything was a problem. if you dont have the right cord.. and you are the only instructor around, and someone shows up.. so your saying that you would deny the student the chance to get a bit of stick time because no one has a buddy cord?? na.. i wouldnt. but hey thats just me.. im not that stuck up like some....... but yeah.... anywho... it was just a suggestion. but then again..i dont let my fat little fingers do things they shouldnt
Old 01-06-2004, 08:50 AM
stomper
My Feedback: (20)
no im not kidding.. i was just throwing suggestions ... so anyways... never said anything was a problem. if you dont have the right cord.. and you are the only instructor around, and someone shows up.. so your saying that you would deny the student the chance to get a bit of stick time because no one has a buddy cord?? na.. i wouldnt. but hey thats just me.. im not that stuck up like some....... but yeah.... anywho... it was just a suggestion. but then again..i dont get my fat little fingers do things they shouldnt
Well I am an instructor and keep Futaba and JR cords in my trailer and yes, no cord no flying. Thats just me as I feel a lot better, and in control with a buddy cord!
Putting tape over the switch just seems crazy to me, but to each there own.
Old 01-06-2004, 08:58 AM
Blackie
Blackie's Avatar
I would like to clear up something for those that do not have an understanding on FM, PPM and PCM. Both PCM and PPM use an FM signal. There are many web sites out there that will give you good information on this.
I'm not an instructor, but have read articles of how its done without the buddy cord and in none of those articles did I read where the instructor and the student do a hand off method, to me thats asking for trouble. I believe the proper way to do it is to allow the student to hold the radio and the instructor place his hands over the student guiding the students stick movements.
Our club does not allow this method its strictly buddy cord.
Old 01-06-2004, 09:06 AM
xp8103
xp8103's Avatar
Man.... I've taught dozens of guys to fly over the years with all manner and make of radio and have never managed to screw something up by passing the transmitter, let alone turn one off......
Edit: Ok... Maybe we've bumped a trim switch....
Old 01-06-2004, 12:52 PM
Flyfalcons
Flyfalcons's Avatar
I don't see how there is any possible way to screw things up as badly as what is written in the first post, except maybe bump the flap switch. Changing models, reversing the ailerons, and "FM-PPM"? Frankly, that's just bull, and I don't think anyone else believes it either.
Old 01-06-2004, 01:04 PM
Blackie
Blackie's Avatar
What a mature thing to say more so coming out of a moderator's mouth.
Old 01-06-2004, 01:23 PM
Flyfalcons
Flyfalcons's Avatar
I am a modeler first, one who owns a 6X and 9C and has flown with a 9Z on a number of occasions. I know for a fact that there are a number of steps to make a major programming change such as different model or modulation type (even if it is the erroneous "FM-PPM" change). Major changes require simultaneous buttons or holding on to a button for over a second to confirm. Heck, it takes that just to get INTO THE PROGRAMMING MENU. So for whoever is quoted in the first post, I for one strongly believe (and with good reason) that you are being much less than honest with the members of RCU.
Old 01-06-2004, 01:24 PM
MikeL
ORIGINAL: Flyfalcons
I'm pretty sure it was satire.
Old 01-06-2004, 01:36 PM
Flyfalcons
Flyfalcons's Avatar
I hope so, it is tough to tell as stated whether it is or not. It is not unheard of for people to make outlandish claims to support their argument.
Old 01-06-2004, 01:37 PM
taxman232ex
taxman232ex's Avatar
To go from ppm to pcm on Futaba radios, you also have to turn the radio off and back on again.
So yes - the one post is crap!!!!
Taxman
MHawker
MHawker's Avatar
I'm lost.[]
Old 01-06-2004, 01:57 PM
Flyboy Dave
My Feedback: (21)
Flyboy Dave's Avatar
Quote:
___________________________________
back to FM.
____________________________________
BALOGNA.....This is not possible....who do you think your kidding ?
On both radios ????? It's joke, right ?....And yes, I also own and operate
a 6xas.
I can see this thread probably won't last long, it's a TROLL....
Old 01-06-2004, 02:32 PM
scottrc
scottrc's Avatar
WOW[X(]!!!! Thanks Mike for seeing the satire
Remember Beaker from the Muppet's
I posted that for these reasons:
1. Blackie was being flamed for posting a concern yet people had to rebuke and balk at him. Just like here.
2. I have the 6xa and David, another member has the 9z. We both have changed modes while not paying attention to the radio and where our fingers are.
They both require an extra amount of time to manage.
The on-off switch is in a bad place. On mine, when new, was really hard to turn off, but after two seasons, the button requires very little pressure to turn off.
3. Not all people are computer literate. They will have what seems !QUOT!bonehead!QUOT! problems with these radios. Help them, not blast them. Then again, this is a !QUOT!club!QUOT!house.
4. Futaba and JR, like any other company, design some features that some people will have problems with, and others feel that are just plain stupid. (I can hold the two buttons down while tuning an engine and switch from mode 1 to 2 just like I can stick my finger in the prop).
5. Futaba will only be accountable if a court rules them accountable, until then, its the consumers responsability.
6. I use my 6xa features to the max on my Warbirds, the technology has made it easier for flight management. I also realized I got what I paid for and feel that I will be retiring this radio after another hard season because some buttons are not working right due to oil residue, the trainer switch has fallen off, and the power switch is getting looser. Poor quality? No, just well used.
Sorry for getting everyones gander up.[]
Scott
Old 01-06-2004, 03:19 PM
BasinBum
Scott, if you have to explain a joke.....Don't expect everyone here to get sarcasm, they all don't have the gene.
I want to start a Buddy Cord thread but can't figure the proper forum, I guess that means the clubhouse?
Old 01-06-2004, 04:13 PM
Flyboy Dave
My Feedback: (21)
There is a radio Forum....and it is popular....
http://www.rcuniverse.com/forum/RC_R...mid_157/tt.htm
Old 01-06-2004, 04:17 PM
taxman232ex
I get sarcasm.
I just don't get how he changed from PPM and PCM without turning the radio on and off. I own 2 8u's and 1 9z and you have to turn the thing on and off to switch between modes. A person would have to try really hard or be stupid to a point that they shouldn't even consider RC airplanes as a hobby to switch accidentally while in flight.
I also understand that turning the radio off while clipping a neck strap on is dumb too. If this switch location is so dangerous and easy to accidentally hit, why don't we hear about it more often? I also don't know about other brands, but on my 9z you have to use more than accidental force to slide the switch off.
Taxman
Old 01-06-2004, 04:30 PM
BasinBum
ORIGINAL: taxman232ex
I get sarcasm.....snip....
Taxman
Not this time you don't. The first post of this thread is a quote from a closed thread and was a joke. Come on Taxman, your usually the one pulling this stuff, still a little groggy from the holidays?
Dave, The radio forum makes sense but I'm more concerned with instruction relating to the buddy cord, not technical aspects.
Old 01-06-2004, 04:40 PM
GrnBrt
GrnBrt's Avatar
Well first off I don't see why there needs to be a closure here but here's my take on it all. I have used Futabas since the 70's and now have a super 7 and a super 8 and have handed them off many times and never have I ever had a problem. I really don't see how all those things stated could happen as it would take a concerned effort to change all those things that were stated.
Old 01-06-2004, 04:42 PM
FLYBOY
FLYBOY's Avatar
This thread must be tail heavy. It went into a spin right from the start.
Seems like more and more just want to flame posters so far this year. Hope that isn't the new trend.
Old 01-06-2004, 09:40 PM
Jim C.
Jim C.'s Avatar
well, the thread was closed and the last thing i read is a big pile of poo... so sue me if i wantted to find out what was going on..
well.. this wasnt ment to flame anyone.. i just wanted to know what was going on.. cuz that poster usually has good stuff and this was a load of hooey.
and it has been going on longer than just this year. everytime i post i end up getting flamed.. so i guess they should grow some thick skin to hang here.
Old 01-06-2004, 09:50 PM
Johnnylightning
Well, I don't intend to flame anybody...it's my New Year's resolution. Try me, I dare you, you boneheads!
Old 01-06-2004, 10:22 PM
Flyboy Dave
My Feedback: (21)
Johnnylightning....
....[sm=thumbup.gif]....you da' man.
