HELP! tranny gear stripped
Old 02-19-2007, 05:08 PM
69eyes
Default HELP! tranny gear stripped
i just stripped the heck out of a tranny gear. does any 1 know what can cause this and how i can prevent it? i have a tmaxx 3.3.
http://www.traxxas.com/products/nitr...x33_tranny.pdf
part # 5395
Old 02-19-2007, 05:44 PM
87warrior
87warrior's Avatar
Default RE: HELP! tranny gear stripped
you can buy metel gears to preventit from doing it again thats what i did
Old 02-20-2007, 09:04 AM
revocat
imo no metal gears will just transfer the force into the rest of tranny
loosen up the slipper & verify proper mesh and try to be off throttle when landing big air
Old 02-20-2007, 09:13 AM
flaminheli
Robinson Racing has the solution. Every gear in my truck was replaced with RR gears front to back.
Old 02-20-2007, 10:26 AM
running_gag
Do you have a metal spur gear? if you do, get rid of it.
Old 02-20-2007, 11:29 AM
BRUSHLESS BASHER
BRUSHLESS BASHER's Avatar
Robinson Racing doesn't make metal gears for this tranny, the trannsmission they make metal gears for is the T-Maxx 2.5, the tranny in the T-Maxx 3.3 is the same as in the Revo, and they don't make metal trannsmission gears for the Revo.
Old 02-20-2007, 04:37 PM
69eyes
i asked my LHS and he said traxxas does not recomend metal tranny gears, and no i have a plastic spur gear and already replaced it once.[:@] my traxxas LOVES to cost me money[:@][][:'(][&o]....... If i had a metal spur gear why would i want to get rid of it?
Old 02-20-2007, 04:51 PM
69eyes
heres some pis: notice all the plastic shrapnel from the gear in the tranny case lol, srry the pics suck
ID:	625926   Click image for larger version
ID:	625927   Click image for larger version
Old 02-20-2007, 07:42 PM
hdking46
been there done that!!!!! i had same problem when i got done with break in.. stripped spur then replaced, but truck wouldnt move[:@] pulled trans apart and found same forward gear stripped. replaced it and put white litheom grease in trans seams to shift better. i had a problem with servo not adjusted right for going into forward & reverse, you had to plimp throttle to get it to move once you moved the switch. truck was sitting still and i hit the throttle and thats when the gear stripped!!!!! once i adjusted the servo rod now it goes in & out forward, reverse with no problem, and i have stripped spurs but no trans gears. oh it is a tmaxx 3.3 sorry for long post ,but hope this helps
Old 02-23-2007, 07:42 PM
alupinit2
Hey 69eyes, I to have stripped the same gears a couple of times 1st due to a stripped reverse servo gears causing it to slip into reverse at high forward speed. 2nd time truck was aprox. 100ft away and the servos started glitching for some reason allowing the reverse servo to engage while moving forward at high speed. Make sure these are not your problems before you strip addtional gears. If I figure out the glitch I will give you an update mean while keep on trucking.
Old 02-23-2007, 10:55 PM
69eyes
thx, u might of got radio interference or low battery, but i think mine stripped b/c i forgot a washer in it when i put it back together but im not sure. i just got the gear today but im too tired to attempt it tonight lol.
