Congratulation!!! Toyan Engine FS-S100 4 Stroke RC Engine Kit Set with Toyan Base
Toyan Engine Set Including: Toyan FS-S100 Engine, Toyan Base ( with throttle push rod, throttle lever, one-button start button, metal tank, battery box ) , Ignition Start Module, Spark Plug, Spark Plug Car.
All the required kits to make engine start, all included. When you get the set, you can start directly. ( Fuel: Methanol, needed prepare by yourself ! )
Fuel: consisting of : 20% castor oil, nitro-methane 5-30%, and the rest is methanol. 20-25% methanol content can be used as fuel. No need 100% pure methanol.
Have you ever used this engine before? Wish to hear your valuable ideas for it. Thanks!
