Lanier Laser 200
Lanier Laser 200
I have a 1/4 scale Lanier Laser 200 kit that I am going to build. I seem to remember some sort of an error pertaining to the plans on this plane. Anyone know anything about this?
I am going to power it with an OS 1.08. As always, trying to build it as light as possible I was going to replace the ABS turtle deck (5.5oz) with a piece of 1/64 ply.
Anything else I should be looking for? The fuselage sides on this kit appear to be 1/8" light ply, not door skins.
Any help will be greatly appreciated.
Bill
Bill
RE: Lanier Laser 200
I built this plane exactly according to the plans, but I put 2 elevator servos in the tail.HUGE MISTAKE. That wound up costing me almost 3/4 pound in the nose.
Build it with the servos where the plans indicate and you'll be rewarded with a model that weighs about 9 pounds RTF.
If your interested, I have the wings for mine. Perfect shape, except for a repair on the trailing edge of the root on one wing. Repair is about 2" long and 3/8" wide. No big deal. I just cracked the foam when I crashed it. Repaired it with 15 minute epoxy and a hobby brush.
I'll sell you the completed wings with Rocket City control horns for a nice price. Here is a pic. Bottom of the wings looks identical to the top, except for the checkerboard on the top of the right wing.
I just remembered; I installed a 2x1" hardwood block in the root of the wing for a 1/4--20 bolt. I used the 1/4--20 bolt to attatch the wing to the fuselage. I didn't like the idea of tapping the aluminum tube and using a small screw for the wing attatchment.
When you get ready to set the incidence, just have everything ready except for the wings. Glue your stab on. Then cut a 2" round piece of ply and drill a 1/4" hole in the center for your alignment dowel. Then you cut a 1/2" hole in the fuselage side where the dowel will set. You put the wing on the tube and slide it into place. It will fit sloppy in the 1/2" hole in the fuse. side. Put your incidence meter on the wing and then glue the 2" piece on the inside of the fuselage. When it dries-- your incidence is perfect.
Goog luck with it and feel free to email me with questions or if you want the wings I have.
Thanks for replying. I'm far enough along on the wings that hopefully, I won't need to get any others, but you never can tell. I like the idea of using bolts thought the fuse sides instead of drilling the wing tube, seen a couple of failures here. (In both cases they managed to get the plane back on the ground safely, but is was close and REAL entertaining)
Later
Bill
Later
Bill
Mine has a 160 Magnum twin 4-stroke, with 3 servos in the tail (and battery!) Balances perfectly, inverted flight with little to no down elevator. Nice aerobatics, I don't fly it fast. Your 1.08 will probably be much faster.
My wings are held with plastic threaded studs epoxied into the foam, and a wing nut inside the fuselage to hold each one on. I cut the heads off toilet seat bolts to make mine.
Good luck,
Dave Olson
Good luck,
Dave Olson
