Help identifying Walbro carburetor number
WI
The engine is a BME 105.
I have a Walbro Carb. and am looking for the right number to use to order a rebuild kit
There is an SDC number on it with an 80 stamped a little distance from the SDC label.
There is a 21-85 on pump cover and 48 on the venturi.
The throttle has a 34-92 stamped on it.
I am guessing that SDC 80 might be the correct number to use when selecting a kit but I only see SDC-80-1 on the Walbro site not just plain SDC 80.
Ebay is your best bet for an sdc 80 or an equally good walbro wj 7 carb , both are obsolete so you just have to keep looking frequently . You could also use carbs for 3w 100 or da 100 engines
My Feedback: (19)
The WJ71 as used on most of the 85, 90, 100 and 120 sized engines should be an excellent replacement for the SDC80. They are the same physical size carb though I believe the venturi on the WJ71 may be a tiny bit smaller. The WJ71 is still a current production carb and available at very reasonable prices .... about $50 or so.
Thank you for the explanation, I was really curious about how does it work. Now, thanks to your post, I know it. I couldn't find anything about it on the internet, so you have really saved me. I had a lot of problems with that numbers, and didn't know what to do. I have even google about the mystical meaning of that numbers, and have read on <!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->https://www.sunsigns.org/angel-number-234-meaning/ that every number has a special power. I don't know if it's true, who knows. But it is really strange.
