3E SMART PLUS 7.4-18.5V LI-PO BATTERY BALANCE CHARGER
LA
does anyone know anything about this charger i'm new to this and would like to make sure what i'm buying will work with the battery that we have for the truck it came with 11.1 volt 5000 battery i hope said that right thanks
RE: 3E SMART PLUS 7.4-18.5V LI-PO BATTERY BALANCE CHARGER
NOOO!!! Dont Buy these. Check the forums, they r chok full of complaints on these things. Mine will take from 75 mins to 3 hours to charge one 3s 2200mah lipo, depending on what kind of mood its in. Not kidding, the cooling fan angrily clicks for several seconds after powering up or until I plug a lipo in. For some reason it charges 3s 800mah in under 45 minutes tho, go figure. I would check around the forums for a better charger. Looking for a multi batt charger/balancer myself. Good luck.[8D]
