Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Tachometer Readings
Saito FG-30 gas 4-stroke performance - peak rpm?
Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Old 07-10-2021, 07:07 AM
Eindecker_pilot
Eindecker_pilot's Avatar
Default Saito FG-30 gas 4-stroke performance - peak rpm?
I am thinking about getting a Saito FG-30 gas 4-stroke engine. I'd like to know what peak RPM people are able to achieve with an 18x6 prop.
Old 10-19-2021, 06:14 PM
Mr kit spit mk959116''
18x10 18x14 10500 11000rpm with YS 140 pipe attached OAT 20'C fast needle peak from 51/2 out from closed position 1/4 close in this peak range but coolpower blue 20% nitro smothered out the instant grunt from take off counter torque roll 11000rpm 2000rpm more from stock 440mm length or 770mm from total length. AN Fitting 35cc gas header flex pipe header I can spin a 19x12 9800rpm full throttle
Old 10-20-2021, 03:38 AM
Eindecker_pilot
Is this with a glow engine or the Saito FG30? You mention 20% nitro so I had to ask. My question is more focused on what kind of RPM people can get with the Saito FG30.
thanks
Old 10-23-2021, 08:42 AM
1967brutus
I cannot give direct readings for lack of an FG30.
I only have direct experience with a Saito 180 that I converted to gasoline for an aquaintance, and that engine managed 2,5 hp@7500 or even slightly better. But that was a different prop (Graupner 3-bladed 16 x 8)
I would expect low 8's with for example an APC 18 x 6W, or high 8's with a MA 18 x 6.
Old 08-15-2022, 06:27 PM
Jesse Open
Jesse Open's Avatar
Excellent numbers but a Saito 180 on gaspoline will never make those numbers,on similar props.
Old 07-04-2024, 01:28 PM
Rcplanedan
Rcplanedan's Avatar
As bert guessed the prop and rpm is very close,
Saito fa150 converted to gas , xoar 18x6 8000rpm.
Saito fa220 zues converted, master airscrew 18x8 8200rpm, this engine is damn great and with the said prop it makes that awesome sound on fly bys,.
Converting a 180 in a couple of days also a fa125
