How to install Aluminum Spinners?
MO
I just need some help on how to install an aluminum spinner. I have a peak model 65cc engine and the screw that holds the prop and prop washer on is a Flat Hex head type. How do I mount an aluminum spinner to that type of bolt? is there a spinner adaptor for it, or will I have to find a different type of bolt and get it tapped? any suggestions would be much apreciated!
Thanx, T.J.
Thanx, T.J.
My Feedback: (19)
RE: How to install Aluminum Spinners?
Most off the engine companies .....Zenoah, Brillelli, BCMA, Fuji, just to mention a few .... offer tapped bolts. You can also get one from Ralph at Rcign. I'm surprised your engine didn't come with one as this is just about a standard engine feature.
MO
Naw, I have an SPE 26cc and it came with one but the Peak 65cc just had the Hex head type bolt. So once I find a tapped bolt I just screw the spinner on with the spinner screw?
My Feedback: (19)
ORIGINAL: T3beatz
http://bcmaengines.com/Accessories.htm
