I am needing help on just about everything on my EVO 35GT
SC
I have a EVO 35GT and have no clue on how to install it on my giant super sportster. The muffler is pitts style and does not fit in the muffler box. I dont know where to put the engine mount. Dont know which hole on the throttle lever to put my control rod on. ANY info should help[:@][:@]
RE: I am needing help on just about everything on my EVO 35GT
Let's start with the throttle. Use the outer most hole at the carb end and the inner most hole at the servo end. That will be about the closest to linear you will get until yo play with a throttle curve in the transmitter.
It's very possible that some modifications will need to be made to accomodate the muffler, or possibly change to a different muffler manufacturer for a slightly different design.
Is it possible for you to upload a couple of pictures of your engine and firewall? That would help a great deal. If I can see the engine and firewall ideas for the mounting will come a lot easier.
