JTEC DA 50 wrap around cracked
MN
After about 45hrs of flight time my wrap around has developed a crack just forward of the front mount screw on the inside, manafold side. Normal wear out item??? The engine and muffler have never been subject to a crash, and I am very careful not to over tighten when mounting. I can provide pictures if you would like.
RE: JTEC DA 50 wrap around cracked
Send it in and let us see it. We will be glad to fix it and return it. Check to make sure you did not overtighten the muffler. You can do that with a straight edge. If it is a warranty issue we will be happy to fix it under our warranty policy. If the header has not been bent it is a quick fix.
Lets see what the problem is and get you fixed up
We will be out of the office at Joe Nall until the 17th
Al Young
JTEC
704-799-1658
Al Young
JTEC
704-799-1658
MN
ORIGINAL: al
Al Young
JTEC
704-799-1658
Al Young
JTEC
704-799-1658
I will try to send it off soon.
Doug
Doug,
we will be At Joe Nall this week. If you can send it to the P.O. box 1847, Mooresville NC 28117 and I will try to get it as soon as we return.
Al
Al
